Software Version
DRIVE OS Linux 5.2.6
[V] DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
[V] Linux
QNX
other
Hardware Platform
[V] NVIDIA DRIVE™ AGX Xavier DevKit (E3550)
other
SDK Manager Version
1.7.1.8928
[V] other
Host Machine Version
[V] native Ubuntu 18.04
other
I created a custom lidar plugin. I pass some command line parameters to it. For example:
./sample_lidar_replay --protocol=lidar.custom --params=ip=127.0.0.1,port=8888,num_of_trxs=6,fps=16,decoder-path=./libnv_opsys_lidar_plugin_x86.so
Then when I want to record to a NVidia .bin file, I run
sudo -s
cd /usr/local/driveworks/tools/capture
./recorder ~/OpsysLidar/opsys_lidar_rig.json
The rig file contains, among other info, the following parameters:
"parameter": "ip=127.0.0.1,port=8888,num_of_trxs=6,fps=16,decoder-path=./libnv_opsys_lidar_plugin_x86.so",
"properties": null,
"protocol": "lidar.custom"
Then I want to replay the recorded .bin file:
./sample_lidar_replay --protocol=lidar.virtual --params=file=./opsys_lidar_front.bin,decoder-path=./libnv_opsys_lidar_plugin_x86.so --show-intensity=false
However I see that when I replay the recorded .bin file, my .so plugin doesn’t know the command line parameters that the recorded .bin file was made with ( The parameters that were written in the opsys_lidar_rig.json file.
The parameters are only passed to the .so plugin in the “dwSAL_createSensor” function, and this function is not called when the sensor is virtual ( played from a Nvidia .bin file )
dwStatus dwSAL_createSensor(dwSensorHandle_t* const sensor, dwSensorParams const params, dwSALHandle_t const sal);
My .so plugin needs to know the value of the command line parameter that is called “num_of_trxs”.
My question is:
- Are the command line parameters that are written in opsys_lidar_rig.json file that I used when a ran the “./recorder”, are also saved somehow in the recorded .bin file? If they are indeed saved within it, how can my .so plugin access them?
- Should I try maybe to solve this issue by creating some .ini/.xml/.json file which will contain our lidar configuration params, so my .so lidar plugin will know which parameters to use when “./sample_lidar_replay” requests from my plugin to replay a .bin file?
- Should I maybe use “./sample_lidar_replay” application, to pass parameters to my .so plugin, while it is in virtual mode ( replaying from a .bin file ) ?
