I’ve recently started working on the Nvidia Drive AGX pegasus. I’m trying to test the lidar data I’ve recorded from a VLP-16 lidar sensor. It’s the data the sensor sends via UDP and I’ve saved it as a .bin file.
However, upon running this command in the terminal :
Thank you for your reply. I’ve gone through the documentation you’ve suggested.
However, my question is still unanswered. I’m trying to view my recorded LIDAR data from VLP-16(supported sensor) using the sample program(sample_lidar_replay) provided with the DriveWorks software. Upon running the command, I get the above mentioned error.
I’ve recorded the data on a windows PC. Could that be a reason for the error? Should the data always be recorded using the recording tool provided?
