How to permanently change network IP and mask of Drive AGX
Software Version
DRIVE OS Linux 5.2.6
[V] DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
[V] Linux
QNX
other
Hardware Platform
[V] NVIDIA DRIVE™ AGX Xavier DevKit (E3550)
other
SDK Manager Version
1.7.1.8928
[V] other
Host Machine Version
[V] native Ubuntu 18.04
other
I want to set the DRIVE AGX “10 GbE port 2” IP and mask.
If I run the following commands, all works fine:
sudo ifconfig enp4s0 172.23.37.10
sudo ifconfig enp4s0 netmask 255.255.255.0
Now I want to make this setting permanent, to last after a reboot.
I tried creating a new file:
sudo gedit /etc/network/interfaces.d/interfaces
# My new file
iface enp4s0 inet static
address 172.23.37.10
Saving and then rebooting, but then when I run “ifconfig” I see that the IP
and mask are not set at all.
Here is the ifconfig printout.
ifconfig log.txt (2.1 KB)
How to permanently change the IP and mask?
Dear @Sunny127,
Does https://docs.nvidia.com/drive/drive-os-5.2.6.0L/drive-os/index.html#page/DRIVE_OS_Linux_SDK_NGC_Development_Guide/config_network_setup.html#wwpID0EXHA help?
By reading: https://docs.nvidia.com/drive/drive-os-5.2.6.0L/drive-os/index.html#page/DRIVE_OS_Linux_SDK_NGC_Development_Guide/config_network_setup.html#wwpID0E04E0HA
I changed the file /etc/network/interfaces t the following content:
# interfaces(5) file used by ifup(8) and ifdown(8)
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
# Content my settings
auto enp4s0
Rebooted.
nvidia@tegra-ubuntu:~$ ifconfig
enP4p1s0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 00:04:4b:f6:6e:ef  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
enp4s0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 00:04:4b:f6:6e:ed  txqueuelen 1000  (Ethernet)
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.115.199.55  netmask 255.255.255.0  broadcast 10.115.199.255
        inet6 fe80::204:4bff:fef6:6eea  prefixlen 64  scopeid 0x20<link>
        ether 00:04:4b:f6:6e:ea  txqueuelen 1000  (Ethernet)
        RX packets 1664  bytes 144657 (144.6 KB)
        RX errors 0  dropped 27  overruns 0  frame 0
        TX packets 1282  bytes 1962802590509 (1.9 TB)
eth0.200: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.42.0.28  netmask 255.255.255.0  broadcast 10.42.0.255
        RX packets 169  bytes 72462 (72.4 KB)
        TX packets 186  bytes 79736 (79.7 KB)
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 321  bytes 141569 (141.5 KB)
        TX packets 321  bytes 141569 (141.5 KB)
The “enp4s0” still has no ip.
I then opened link: https://docs.nvidia.com/drive/drive-os-5.2.6.0L/drive-os/index.html#page/DRIVE_OS_Linux_SDK_NGC_Development_Guide/config_network_setup.html#wwpID0EXHA
Created a file “/etc/netplan/01-network-manager-all.yaml”
 network:
         version: 2
         renderer: networkd
         ethernets:
              enp4s0:
                  dhcp4: no
                  dhcp6: no
                  addresses:
                             - 172.23.37.10/22
                  gateway4: 172.23.37.1
ran:
sudo netplan apply
sudo reboot
The ifconfig shows that “enp4s0” still has no ip.
Any ideas?
Dear @Sunny127,
Could you share connection details and dmseg and syslog outputs
Here are the connection details, dmesg and syslog outputs:
dmesg.txt (68.6 KB)
ethtool.txt (999 Bytes)
ifconfig.txt (3.0 KB)
ip link show.txt (1.2 KB)
netstat.txt (558 Bytes)
syslog.txt (14.6 MB)
Dear @Sunny127,
Could you please confirm if you still have this issue?
I indeed still have the issue.
Is there any solution to this question? I have the same question as well.
Thank you,
@SivaRamaKrishnaNV
Any ideas, does modify /etc/systemd/networks works?
why default does not have eth0.400, eth0.900 vlan info
When I started using DHCP to automatically assign IP addresses to computers and devices in our house, I could change the subnet mask for all of them using the administration interface of my router. I found this out when I wanted to change the IP address on Android by visiting How to Change the IP Address on Your Android Device before doing so. I use the web browser on my computer to access the router’s web interface. To do this, I must go to the router’s address and log in with my account and password. On most routers, this is 192.168.0.1 or 192.168.1.1, but they can vary.
Thank you,
