Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
I am trying to set static IPs on the 2 10 GbE ports on the back of Pegasus. From My understanding port 1 corresponds to Xavier A, and port 2 corresponds to Xavier B. I was successfully able to set the static IP of port 1 through xavier A by modifying the file /etc/systemd/network/99-nv_enps0_default.network for device enp4s0 and then running the command sudo systemctl restart systemd-networkd. However, when repeating the same steps for Xavier B I am unable to get the connection to work. I am setting the ip in the same file on Xavier B for device name enp3s0 (I don’t see an enp4s0 on Xavier B), and using the same command to restart but in the ifconfig output the device is up and not running.
Dear @ikhalip,
Could you share the changes made to get static IP for enp3s0 interface?
