I confirmed my Pegasus for getting 2 static IP in rear panel (defined in /etc/network/interfaces) for 10GbE ports, it always needs to restart manually (restart to /etc/init.d/networking) Drive OS’s network service after system booting finished. It seems to be a issue within Drive OS 5.1.
Could you please help to check them to let me file nvonline bug.
I configure static IP to that 2 10GbE ports in rear view of my Pegasus then restart system (I’m sure network service is enabled), IP still cannot be probed and need to restart networking service (via /etc/init.d/networking restart).
Please clarify the issue first.
Could you just share the steps to reproduce issue? What do you connect to the 10GbE port?
You mentioned “rear panel”, so do you connect it to 2 lcd panel?
Also, you said " It seems to be a issue within Drive OS 5.1. ", so this issue was not there if using previous release?
