Pegasus ethernet setting issue
Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.4.1.7402
other
Host Machine Version
native Ubuntu 18.04
other
when i start the pegasus board, plugin the keyboard and mouse, ifconfig can get the eth*, i used another pc to connect it. config the ip, but the ping always failed. ssh failed.
Dear @yafei.meng,
Could you share the DRIVE SW version and ifconfig output?
As @SivaRamaKrishnaNV replied, could you provide your information by checking these checkboxs in your post?
If you are using DRIVE OS 5.2.0, you will need to follow DRIVE OS Linux SSH Server to install ssh server. Thanks.
I think i have solved this issue.
I connect the pegasus and pc directly. and have to config static ip address instead of DHCP.
Dear @yafei.meng ,
Glad to hear that. Could you share the complete steps here to help others in the community?
