How to Publish Depth Topics Along with YOLOv8 Object Detection on Jetson Orin Nano
I followed the NVIDIA Isaac ROS YOLOv8 Quickstart isaac_ros_yolov8 Quickstart and successfully ran it on my Jetson Orin Nano and Intel RealSense Depth Camera , although I noticed it’s a bit heavy on the system.
Now, I would like to publish depth topics from the RealSense camera together with the object detection results from isaac_ros_yolov8. Could anyone guide me on how to set this up? Any advice or recommendations would be greatly appreciated.
My environment is as follows:
  • Device: Jetson Orin Nano
  • Camera: Intel RealSense Depth Camera D457 (connected via USB3.2)
  • Operating System: JetPack 6.0 (rev2)
Thank you!
Hi @sakamaki
Thank you for your post.
To publish depth topics from realsense2_camera for this yolov8 demo, you can set enable_depth as true in /opt/ros/humble/share/isaac_ros_realsense/config/realsense_mono.yaml.
Hi @Ahung ,
Thank you for your advice!
I followed the settings as you suggested, and the depth topics were successfully published.
I really appreciate your help!
Best regards,
sakamaki
