I’m running some processes on a Jetson NX and I was trying to isolate 3 of the cores so I could use taskset and dedicate them to my python script which incorporated multi processing. To do this, I followed a few tutorials and modified my /boot/extlinux/extlinux.conf
file to be:
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL primary
MENU LABEL primary kernel
LINUX /boot/Image
INITRD /boot/initrd
APPEND ${cbootargs} quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=3-5
This worked fine for my needs and when I ran cat /sys/devices/system/cpu/isolated
it outputted 3-5
. Now I’m trying to bring back cores 3 and 4, so I modified the extlinux.conf file to say:
TIMEOUT 30
DEFAULT primary
LABEL primary
LINUX /boot/Image
INITRD /boot/initrd
APPEND ${cbootargs} quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=5
and I rebooted my Jetson. However It still says cores 3-5 are isolated. Is there some other steps I need to take to re-enable these cores?
