I am new to Nvidia Omniverse, trying to generate synthetic data. I want to add my own sphere light, so I do not need the default LIGHT. How can I remove the default light entirely?
These are the codes I used:
with rep.new_layer():
# Path for gears, work table, and the environment
GEARS = 'omniverse://localhost/Projects/GearGenerator/Assets/Gears'
TABLE = 'omniverse://localhost/Projects/GearGenerator/Assets/Surfaces/KIRoPro_Arbeitstisch.usd'
ENVS = 'omniverse://localhost/NVIDIA/Assets/Scenes/Templates/Interior/ZetCG_ExhibitionHall.usd'
# OmniPBR materials used for the gears. More info: https://docs.omniverse.nvidia.com/prod_materials-and-rendering/prod_materials-and-rendering/materials.html
mats = rep.create.material_omnipbr(diffuse=rep.distribution.uniform((0,0,0), (1,1,1)),
metallic=rep.distribution.choice([0, 0.5, 0.75, 1]),
count=50
# Define camera
camera = rep.create.camera(position=(0, 1300, 500), rotation=(-45, 0, 0))
render_product = rep.create.render_product(camera, (1024, 1024))
# Define randomizer function for gears
def get_gears(size=3):
instances = rep.randomizer.instantiate(rep.utils.get_usd_files(GEARS, recursive=True), size=size, mode='scene_instance')
with instances:
rep.modify.semantics([("class", "gear")])
rep.modify.pose(
position=rep.distribution.uniform((-200, 800, -200), (200, 900, 200)),
rotation=rep.distribution.uniform((-180, -180, -180), (180, 180, 180)),
scale=1.5
rep.randomizer.materials(mats)
return instances.node
# Adding and randomizing light source
def sphere_lights():
lights = rep.create.light(
light_type="Sphere",
color=rep.distribution.uniform((0, 0, 0), (255, 255, 255)),
intensity=rep.distribution.uniform(1000, 35000),
position=rep.distribution.uniform((-500, 800, -500), (500, 1600, 500)),
scale=rep.distribution.uniform(50, 100)
return lights.node
# Register randomization
rep.randomizer.register(get_gears)
rep.randomizer.register(sphere_lights)
# Create environment and work table
env = rep.create.from_usd(ENVS)
surface = rep.create.from_usd(TABLE)
with surface:
rep.modify.pose(
position = (0, 435, 0),
rotation = (-90, 0, 0),
scale = 1000
# Generate frames
with rep.trigger.on_frame(num_frames=10):
rep.randomizer.get_gears()
rep.randomizer.sphere_lights()
# Initialize and attach writer
writer = rep.WriterRegistry.get("BasicWriter")
writer.initialize(
output_dir="~/Documents/GearProject/gearproject/datasets/rand_light",
rgb=True,
bounding_box_2d_tight=True
writer.attach([render_product])
# Simulate in Omniverse Code
rep.orchestrator.run()
