I am trying to use dome lights to have a non-black background to the object I want to recognize. I am unable to do this as the background remains black.
This is the code I’m attempting to use:
NUM_FRAMES = 5
RT_SUBFRAMES = 50
rep.settings.set_render_pathtraced(samples_per_pixel=64)
with rep.new_layer():
camera = rep.create.camera(
position=(60, 50, 200),
look_at=(0, 0, 0)
render_product = rep.create.render_product(camera, (640, 480))
slab = rep.create.plane(
position=(0, 0, 0),
scale=[0.6, 1, 0.9],
rotation=(0, 0, 0),
pivot=(0, 0, -0.8),
house = rep.create.cube(
position=(-20, 0, 0),
scale=(0.2, 0.15, 0.05),
pivot=(0, -1, 0)
writer = rep.WriterRegistry.get("BasicWriter")
writer.initialize(output_dir="camera_output", rgb=True)
writer.attach([render_product])
def dome_lights():
lights = rep.create.light(
light_type="Dome",
intensity=1000,
texture=rep.distribution.choice([
'omniverse://localhost/NVIDIA/Assets/Skies/Cloudy/champagne_castle_1_4k.hdr',
'omniverse://localhost/NVIDIA/Assets/Skies/Clear/evening_road_01_4k.hdr',
'omniverse://localhost/NVIDIA/Assets/Skies/Clear/mealie_road_4k.hdr',
'omniverse://localhost/NVIDIA/Assets/Skies/Clear/qwantani_4k.hdr'
return lights.node
rep.randomizer.register(dome_lights)
with rep.trigger.on_frame(max_execs=NUM_FRAMES,
rt_subframes=RT_SUBFRAMES):
rep.randomizer.dome_lights()
rep.orchestrator.run()
This is a resulting image (they all look the same):
The only error i get in the entire log is this:
and I get this warning if that is relevant:
OgnSdPostRenderVarToHost : rendervar copy from texture directly to host buffer is counter-performant. Please use copy from texture to device buffer first.
In the Kit Base Editor I am able to press Locate file
on the texture indicating that it is able to find the texture.
Thanks for the help!
Edit: I now got it working with a hack. If i just run the script it doesn’t work but if I create a new dome light in the scene in the KIT app that leads to the textures being imported. Then I can remove the newly added dome light and re-run the script and it works. Very strange but at least a temporary fix.
