I’m trying to import a random selection of usd’s into an omniverse scene from a folder on my computer. I’ve tried the example code that uses assets from Nucleus, and I’m able to call assets for dome light textures. I’m not sure what going wrong or why I’m getting this error. Here’s the code as well as the log.
kit_20221206_152022.log (3.0 MB)
with rep.new_layer():
camera = rep.create.camera(position=(0, 0, 1300), focal_length = 18.14756)
render_product = rep.create.render_product(camera, (1920, 1200))
bottles = '/home/ubuntu/Documents/AIM/Bottles/USD/middle'
theCone = rep.create.cone(semantics=[('class', 'cone')], position=(0, 0, -201), rotation=(90,0,0), scale=(21.4, 29.9, 12), visible=False)
def dome_light():
dome = rep.create.light(
light_type="Dome",
rotation=(270,0,0),
texture=rep.distribution.choice([
'/home/ubuntu/Documents/AIM/EXR/belfast_sunset_4k.hdr',
'/home/ubuntu/Documents/AIM/EXR/belfast_sunset_puresky_4k.hdr',
'/home/ubuntu/Documents/AIM/EXR/castel_st_angelo_roof_4k.hdr',
'/home/ubuntu/Documents/AIM/EXR/clarens_midday_4k.hdr',
'/home/ubuntu/Documents/AIM/EXR/garden_nook_4k.hdr',
'/home/ubuntu/Documents/AIM/EXR/golf_course_sunrise_4k.hdr',
'/home/ubuntu/Documents/AIM/EXR/lythwood_field_4k.hdr',
'/home/ubuntu/Documents/AIM/EXR/noon_grass_4k.hdr',
'/home/ubuntu/Documents/AIM/EXR/pretville_cinema_4k.hdr',
'/home/ubuntu/Documents/AIM/EXR/rainforest_trail_4k.hdr',
'/home/ubuntu/Documents/AIM/EXR/rustig_koppie_puresky_4k.hdr',
'/home/ubuntu/Documents/AIM/EXR/snowy_field_4k.hdr',
'/home/ubuntu/Documents/AIM/EXR/sunflowers_4k.hdr',
'/home/ubuntu/Documents/AIM/EXR/wide_street_01_4k.hdr'
return dome.node
rep.randomizer.register(dome_light)
def distant_light():
sun = rep.create.light(
light_type = "Distant",
position = rep.distribution.uniform((-3000, -3000, -3000), (3000, 3000, 3000)),
intensity = rep.distribution.uniform(3000, 7000),
look_at = (0, 0, 0)
return sun.node
rep.randomizer.register(distant_light)
def move_shapes(size=14):
instances = rep.randomizer.instantiate(rep.utils.get_usd_files(bottles), size=size, mode='point_instance')
with instances:
rep.modify.pose(
rep.modify.pose(rotation = rep.distribution.uniform((0, 0, 0), (360, 360, 360))),
rep.randomizer.scatter_3d(volume_prims=theCone, check_for_collisions=True)
return instances.node
rep.randomizer.register(move_shapes)
with rep.trigger.on_time(interval=1, num=51):
rep.randomizer.move_shapes()
rep.randomizer.dome_light()
rep.randomizer.distant_light()
writer = rep.WriterRegistry.get("BasicWriter")
writer.initialize(
output_dir="BottleStorm4.0500",
rgb=True,
bounding_box_2d_loose=True,
instance_segmentation=True
writer.attach([render_product])
