We are developing customize carrier board.
One of board changes is eliminating USB type c and replacing it with USB 2.0.
During integration we encounter errors about display port which we thinks are came from display port module.
��WARNING: pll_d has no dyn ramp
WARNING: pll_d2 has no dyn ramp
��[ 1.779649] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.779711] tegradc 15210000.nvdisplay: dp: Failed for I2C write addr:80, size:1, stat:0x10000100
[ 1.789344] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.789378] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.794611] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.794652] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.799873] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.799903] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.805166] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.805197] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.805225] tegradc 15210000.nvdisplay: dp: failed to exit panel power save mode (0xfffffff2)
[ 1.822523] tegradc 15220000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.822566] tegradc 15220000.nvdisplay: dp: Failed for I2C write addr:80, size:1, stat:0x10000100
[ 1.831594] tegradc 15220000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.831628] tegradc 15220000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.836820] tegradc 15220000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.836848] tegradc 15220000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.842017] tegradc 15220000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.842043] tegradc 15220000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.847266] tegradc 15220000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.847292] tegradc 15220000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.847318] tegradc 15220000.nvdisplay: dp: failed to exit panel power save mode (0xfffffff2)
[ 1.921753] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.921788] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.926741] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.926749] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.931783] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.931789] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.936976] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.936982] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.936987] tegradc 15210000.nvdisplay: dp: failed to exit panel power save mode (0xfffffff2)
[ 1.936994] hpd: edid read prepare failed
[ 1.961780] tegradc 15220000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.961787] tegradc 15220000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.966886] tegradc 15220000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.966892] tegradc 15220000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.972017] tegradc 15220000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.972023] tegradc 15220000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.977153] tegradc 15220000.nvdisplay: dp: aux write got error (0x10000100)
[ 1.977159] tegradc 15220000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.977163] tegradc 15220000.nvdisplay: dp: failed to exit panel power save mode (0xfffffff2)
[ 1.977169] hpd: edid read prepare failed
��WARNING: pll_d3 has no dyn ramp
��[ 2.196148] tegra-xudc-new 3550000.xudc: extcon_get_extcon_dev_by_cable failed -19
[ 6.652078] cgroup: cgroup2: unknown option "nsdelegate"
[ 7.912310] random: crng init done
[ 7.912442] random: 7 urandom warning(s) missed due to ratelimiting
[ 72.833346] Please complete system configuration setup on desktop to proceed...
In order to solve the problem I tried to disable display port at disp dtsi to disable display port bu it did not work.
What should I do in order to disable the default DP as it comes at xavier developmment kit.
And i addition to that how to add another HDMI output.
tegra194-e3366-disp.dtsi (3.1 KB)
tegra194-p2888-0001-p2822-0000-common.dtsi (8.3 KB)
t19x.zip (296.2 KB)
