You would need to add custom metadata. Please refer to the sample:
@prerana5626 As the pipeline image shows, dsexample is not before the msgconv by default, so you can’t receive the frame_image. You can move dsexample bin to the right position.
I have the same problem. imwrite cause crash…
The same code i use deepstream-app works well, but use deepstream-test5 cause crash. when save the image.
Please help to open a new topic for your issue. Thanks
Hello, I tried to add a new callback function, but I can’t distinguish the stream frame. What should I do
This is where I add the callback function, because I don’t know exactly where the callback function should be added
I am using test5, and I want to save frame img, which place should I put these code ?
Hi DaneLLL,
I did’t find the function tracking_done_buf_prob() you mentioned in Saving frame with detected object [Jetson Nano, DS4.0.2] - #3 by DaneLLL
As I am using deepstream-test5 (deepstream 5.1) , I want to save frame image. I can get the batchmeta and framemata from “bbox_generated_probe_after_analytics ()” . can you tell me how to use this code? how can I get “*dsexample” ?
static gint dump = 0;
if (dump < 150) {
char filename[64];
snprintf(filename, 64, “/tmp/image%03d.jpg”, dump);
cv::imwrite(filename, *dsexample->cvmat);
dump++;
Please create a new topic for clearness. Thanks.
hi DaneLLL, thanks for your quick response, a new topic is created here:
