I am running Python, for example: set a Cube rotation, the 3D screen will directly give me the result of the rotation, without the process of rotation. Hope to see the rotation process in 3D view.Hope I can get some help, thanks.
Hi @fsb0147 - To see the rotation process in the 3D view, you need to animate the rotation over time. This can be done by setting up a loop that gradually changes the rotation of the cube and then updates the scene.
Here is a simple example of how you might do this in Python:
import time
from omni.isaac.dynamic_control import _dynamic_control
dc = _dynamic_control.acquire_dynamic_control_interface()
# Assuming cube_prim is the prim of your cube
cube_handle = dc.get_rigid_body("/World/cube")
for i in range(100):
# Compute the new rotation
new_rotation = Gf.Rotation(Gf.Vec3d(0, 0, 1), i)
# Set the rotation of the cube
dc.set_rigid_body_pose(cube_handle, Gf.Vec3f(0, 0, 0), new_rotation.GetQuaternion())
# Update the scene
dc.update_rigid_body_states()
# Wait for a short time before the next update
time.sleep(0.01)
This script will rotate the cube around the Z-axis over the course of 1 second. You can adjust the range of the loop, the rotation calculation, and the sleep time to get the effect you want.
Hi,@rthaker Thank you for your help, I copied the code, but it doesn’t work, as shown in the picture, I don’t know why. In addition, I have another question, if my cube_handle = dc.get_rigid_body(“/World/Xform/cube”), will it take effect? I want to control the whole Xform rotation.
according to set_rigid_body_pose, you need to use a transform. Convert your position and rotation with the following
q = new_rotation.GetQuaternion()
t = dc.Transform()
t.p = [0,0,0]
t.r = [q.x, q.y, q.z, q.w]
then call dc.set_rigid_body_pose(cube_handle, t)
@rgasoto I’m very sorry, he still prompted an error,
“2023-09-14 09:14:05 [Error] [omni.kit.app.plugin] [py stderr]: AttributeError: ‘omni.isaac.dynamic_control._dynamic_control.Dynami’ object has no attribute ‘Tansform’”
Sorry, I had a typo on my code, It should be dc.Transform()… I updated it in the original snippet too
@rgasoto
2023-09-25 02:31:07 [Error] [omni.kit.app.plugin] [py stderr]: AttributeError: ‘omni.isaac.dynamic_control._dynamic_control.Dynami’ object has no attribute ‘Transform’
This kind of error still exists. Could you please provide me with a complete code study?
from pxr import Gf
import time
dc=_dynamic_control.acquire_dynamic_control_interface()
import asyncio
#Assuming cube_prim'is the prim ofyour cube|
cube_handle = dc.get_rigid_body("/World/Cube")
async def run():
for i in range (100):
v= q.GetImaginary()
t = _dynamic_control.Transform()
t.p= [0,0,10]
t.r = [v[0], v[1], v[2], q.GetReal()]
# Set therotation of the cube
await omni.kit.app.get_app().next_update_async()
asyncio.ensure_future(run())
