Hardware:
Jetson AGX Orin based CustomBoard
BSP:
L4T 35.5.0
We are using the TLV320AIC3110 as an AUDIO CODEC in AGX Orin based environment.
The Tegra side is operated as Master and the CODEC side as Slave, and MCLK is supplied from the Tegra SoC.
Basic Play/Record is available.
However, during playback, we confirmed that PLL_A_OUT0 and MCLK change dynamically depending on the sampling rate.
・startup
[ 33.977991] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, sample rate = 44100 Hz
・playing
[ 47.195316] pll_a_out0 = 49152000 Hz, aud_mclk = 12288000 Hz, sample rate = 48000 Hz
This seems to be the cause of the noise in sine wave playback, etc.
To change AUD_MCLK to exactly 120000000 Hz with fixed settings, we have already tried the following steps.
AUD_MCLK for Codec SYSCLK
https://docs.nvidia.com/jetson/archives/r35.4.1/DeveloperGuide/text/SD/Communications/AudioSetupAndDevelopment.html#aud-mclk-for-codec-sysclk
[cvb/tegra234-p3737-audio-codec-tlv320aic311x.dtsi]
tegra_sound: sound {
compatible = "nvidia,tegra186-ape";
nvidia-audio-card,name = "NVIDIA Jetson AGX Orin APE";
clocks = <&bpmp_clks TEGRA234_CLK_PLLA>,
<&bpmp_clks TEGRA234_CLK_PLLA_OUT0>,
<&bpmp_clks TEGRA234_CLK_AUD_MCLK>;
clock-names = "pll_a", "pll_a_out0", "extern1";
assigned-clocks = <&bpmp_clks TEGRA234_CLK_AUD_MCLK>;
assigned-clock-parents = <&bpmp_clks TEGRA234_CLK_PLLA_OUT0>;
+ assigned-clock-rates = <0>, <12000000>;
nvidia-audio-card,widgets =
"Microphone", "TI-TLV320 Microphone Jack",
"Headphone", "TI-TLV320 Headphone Jack",
"Speaker", "TI-TLV320 Speaker Left",
"Speaker", "TI-TLV320 Speaker Right";
nvidia-audio-card,routing =
"TI-TLV320 MIC1LP", "TI-TLV320 Microphone Jack",
"TI-TLV320 MIC1RP", "TI-TLV320 Microphone Jack",
"TI-TLV320 MIC1LP", "TI-TLV320 MICBIAS",
"TI-TLV320 MIC1RP", "TI-TLV320 MICBIAS",
"TI-TLV320 Headphone Jack", "TI-TLV320 HPL",
"TI-TLV320 Headphone Jack", "TI-TLV320 HPR",
"TI-TLV320 Speaker Left", "TI-TLV320 SPL",
"TI-TLV320 Speaker Right", "TI-TLV320 SPR";
nvidia-audio-card,mclk-fs = <256>;
status = "okay";
However, as shown below, the assigned-clock-rates do not seem to be reflected.
# speaker-test -c2 -D plughw:APE -twav -l 1
speaker-test 1.2.2
Playback device is plughw:APE
Stream parameters are 48000Hz, S16_LE, 2 channels
WAV file(s)
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 32 to 8192
Period size range from 32 to 4096
Using max buffer size 8192
Periods = 4
[ 608.887521] pll_a_out0 = 49152000 Hz, aud_mclk = 12288000 Hz, sample rate = 48000 Hz
was set period_size = 2048
was set buffer_size = 8192
0 - Front Left
1 - Front Right
Time per period = 2.857470
# cat /sys/kernel/debug/clk/clk_summary | grep aud_mclk
aud_mclk 15 15 0 12287988 12288000 0 0 50000
Could you please tell me how to fix AUD_MCLK at an arbitrary rate?
