How to set 'joint_velocity_cap_rmp' in rmpflow.yaml file as more than one velocity in the urdf file
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo (GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim) following the instructions provided on Isaac Lab’s Contributing Guidelines (Contribution Guidelines — Isaac Lab Documentation).
Isaac Sim Version
[v] 4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
[v] Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
NVIDIA GeForce RTX 4070
NVIDIA-SMI 535.183.01
Topic Description
Detailed Description
It says " There is one RMPflow parameter that is robot-specific: joint_velocity_cap_rmp. This term sets a limit on the maximum velocity that is allowed by RMPflow for any joint in the specified configuration space. Investigating the URDF, we can see that each joint in the Cobotta Pro 900 has a velocity limit of 1 rad/s." in the upon website.
But in the urdf of our robotic arm, there are three velocities of different joints, as 1(gripper),3(end effort) and 5(other), so which velocity should I set to the joint_velocity_cap_rmp parameter?
Steps to Reproduce
(Add more steps as needed)
Error Messages
(If applicable, copy and paste any error messages you received)
Screenshots or Videos
(If applicable, add screenshots or links to videos that demonstrate the issue)
Additional Information
What I’ve Tried
(Describe any troubleshooting steps you’ve already taken)
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
(Add any other context about the problem here)
