Thank you, linuxdev, after I modified the xorg.conf as you listed, the /var/log/Xorg.0.log I can get is like below, it’s quite long, always repeat the last lines like below the end lines.
I can the ubuntu desktop after the reboot, but when i choose to login by typed the password, the display hung there showing the purple blank desktop. And i found i forgot to get the log before doing anything.
Sorry I’m new to the TX2, have lots of problems when start to use.
[ 18.172]
X.Org X Server 1.18.4
Release Date: 2016-07-19
[ 18.172] X Protocol Version 11, Revision 0
[ 18.172] Build Operating System: Linux 4.4.0-45-generic aarch64 Ubuntu
[ 18.172] Current Operating System: Linux tegra-ubuntu 4.4.15-tegra #1 SMP PREEMPT Wed Mar 1 21:09:29 PST 2017 aarch64
[ 18.172] Kernel command line: fbcon=map:0 net.ifnames=0 console=tty0 OS=l4t console=ttyS0,115200n8 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 android.kerneltype=normal androidboot.serialno=0335115020673 vpr_resize root=/dev/mmcblk0p1 rw rootwait
[ 18.172] Build Date: 02 November 2016 10:05:28PM
[ 18.172] xorg-server 2:1.18.4-0ubuntu0.2 (For technical support please see http://www.ubuntu.com/support)
[ 18.172] Current version of pixman: 0.33.6
[ 18.172] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 18.172] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 18.172] (==) Log file: "/var/log/Xorg.0.log", Time: Fri May 6 05:40:13 2016
[ 18.175] (==) Using config file: "/etc/X11/xorg.conf"
[ 18.175] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 18.177] (==) No Layout section. Using the first Screen section.
[ 18.177] (==) No screen section available. Using defaults.
[ 18.177] (**) |-->Screen "Default Screen Section" (0)
[ 18.177] (**) | |-->Monitor "<default monitor>"
[ 18.177] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 18.177] (**) | |-->Device "Tegra0"
[ 18.177] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 18.177] (==) Automatically adding devices
[ 18.178] (==) Automatically enabling devices
[ 18.178] (==) Automatically adding GPU devices
[ 18.178] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 18.179] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 18.179] Entry deleted from font path.
[ 18.179] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 18.179] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 18.180] Entry deleted from font path.
[ 18.180] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 18.180] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 18.180] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 18.180] (==) ModulePath set to "/usr/lib/aarch64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 18.180] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 18.180] (II) Loader magic: 0x5574dccd80
[ 18.180] (II) Module ABI versions:
[ 18.180] X.Org ANSI C Emulation: 0.4
[ 18.180] X.Org Video Driver: 20.0
[ 18.180] X.Org XInput driver : 22.1
[ 18.180] X.Org Server Extension : 9.0
[ 18.181] (++) using VT number 7
[ 18.181] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 18.181] (II) no primary bus or device found
[ 18.181] (WW) "dri" will not be loaded unless you've specified it to be loaded elsewhere.
[ 18.181] (II) "glx" will be loaded by default.
[ 18.181] (II) LoadModule: "extmod"
[ 18.181] (II) Module "extmod" already built-in
[ 18.181] (II) LoadModule: "glx"
[ 18.182] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 18.206] (II) Module glx: vendor="X.Org Foundation"
[ 18.206] compiled for 1.18.4, module version = 1.0.0
[ 18.206] ABI class: X.Org Server Extension, version 9.0
[ 18.206] (==) AIGLX enabled
[ 18.206] (II) LoadModule: "nvidia"
[ 18.207] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 18.218] (EE) Failed to load /usr/lib/xorg/modules/drivers/nvidia_drv.so: libnvidia-rmapi-tegra.so.27.1.0: cannot open shared object file: No such file or directory
[ 18.218] (II) UnloadModule: "nvidia"
[ 18.218] (II) Unloading nvidia
[ 18.218] (EE) Failed to load module "nvidia" (loader failed, 7)
[ 18.218] (==) Matched modesetting as autoconfigured driver 0
[ 18.218] (==) Matched fbdev as autoconfigured driver 1
[ 18.218] (==) Assigned the driver to the xf86ConfigLayout
[ 18.218] (II) LoadModule: "modesetting"
[ 18.219] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 18.225] (II) Module modesetting: vendor="X.Org Foundation"
[ 18.225] compiled for 1.18.4, module version = 1.18.4
[ 18.225] Module class: X.Org Video Driver
[ 18.225] ABI class: X.Org Video Driver, version 20.0
[ 18.225] (II) LoadModule: "fbdev"
[ 18.225] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 18.226] (II) Module fbdev: vendor="X.Org Foundation"
[ 18.226] compiled for 1.18.1, module version = 0.4.4
[ 18.226] Module class: X.Org Video Driver
[ 18.226] ABI class: X.Org Video Driver, version 20.0
[ 18.226] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 18.226] (II) FBDEV: driver for framebuffer: fbdev
[ 19.249] (WW) Falling back to old probe method for modesetting
[ 19.250] (EE) open /dev/dri/card0: No such file or directory
[ 19.250] (WW) Falling back to old probe method for fbdev
[ 19.250] (II) Loading sub module "fbdevhw"
[ 19.250] (II) LoadModule: "fbdevhw"
[ 19.251] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 19.252] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 19.252] compiled for 1.18.4, module version = 0.0.2
[ 19.252] ABI class: X.Org Video Driver, version 20.0
[ 19.252] (II) FBDEV(0): using default device
[ 19.252] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 19.252] (II) FBDEV(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 19.252] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
[ 19.252] (==) FBDEV(0): RGB weight 888
[ 19.252] (==) FBDEV(0): Default visual is TrueColor
[ 19.252] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[ 19.252] (II) FBDEV(0): hardware: tegra_fb (video memory: 73728kB)
[ 19.252] (II) FBDEV(0): checking modes against framebuffer device...
[ 19.252] (II) FBDEV(0): checking modes against monitor...
[ 19.252] (--) FBDEV(0): Virtual size is 1920x1080 (pitch 1920)
[ 19.252] (**) FBDEV(0): Built-in mode "current": 148.5 MHz, 67.5 kHz, 60.0 Hz
[ 19.252] (II) FBDEV(0): Modeline "current"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync -csync (67.5 kHz b)
[ 19.252] (==) FBDEV(0): DPI set to (96, 96)
[ 19.252] (II) Loading sub module "fb"
[ 19.252] (II) LoadModule: "fb"
[ 19.253] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 19.254] (II) Module fb: vendor="X.Org Foundation"
[ 19.254] compiled for 1.18.4, module version = 1.0.0
[ 19.254] ABI class: X.Org ANSI C Emulation, version 0.4
[ 19.254] (**) FBDEV(0): using shadow framebuffer
[ 19.254] (II) Loading sub module "shadow"
[ 19.254] (II) LoadModule: "shadow"
[ 19.254] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 19.254] (II) Module shadow: vendor="X.Org Foundation"
[ 19.254] compiled for 1.18.4, module version = 1.1.0
[ 19.254] (II) UnloadModule: "modesetting"
[ 19.254] (II) Unloading modesetting
[ 19.254] (==) Depth 24 pixmap format is 32 bpp
[ 21.272] (==) FBDEV(0): Backing store enabled
[ 21.272] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[ 21.273] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[ 21.274] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[ 21.275] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[ 21.275] (==) FBDEV(0): DPMS enabled
[ 21.275] (==) RandR enabled
[ 21.282] (II) SELinux: Disabled on system
[ 21.283] (II) AIGLX: Screen 0 is not DRI2 capable
[ 21.283] (EE) AIGLX: reverting to software rendering
[ 21.470] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 21.471] (II) AIGLX: Loaded and initialized swrast
[ 21.471] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 21.566] (II) config/udev: Adding input device tegra-hda HDMI/DP,pcm=3 (/dev/input/event0)
[ 21.566] (II) No input driver specified, ignoring this device.
[ 21.566] (II) This device may have been added with another device file.
[ 21.566] (II) config/udev: Adding input device tegra-hda HDMI/DP,pcm=7 (/dev/input/event1)
[ 21.567] (II) config/udev: Adding input device CHICONY HP Basic USB Keyboard (/dev/input/event4)
[ 21.567] (**) CHICONY HP Basic USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 21.567] (II) LoadModule: "evdev"
[ 21.567] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 21.571] (II) Module evdev: vendor="X.Org Foundation"
[ 21.571] compiled for 1.18.1, module version = 2.10.1
[ 21.571] Module class: X.Org XInput Driver
[ 21.571] ABI class: X.Org XInput driver, version 22.1
[ 21.571] (II) Using input driver 'evdev' for 'CHICONY HP Basic USB Keyboard'
[ 21.571] (**) CHICONY HP Basic USB Keyboard: always reports core events
[ 21.571] (**) evdev: CHICONY HP Basic USB Keyboard: Device: "/dev/input/event4"
[ 21.571] (--) evdev: CHICONY HP Basic USB Keyboard: Vendor 0x3f0 Product 0x24
[ 21.571] (--) evdev: CHICONY HP Basic USB Keyboard: Found keys
[ 21.571] (II) evdev: CHICONY HP Basic USB Keyboard: Configuring as keyboard
[ 21.571] (**) Option "config_info" "udev:/sys/devices/3530000.xhci/usb1/1-2/1-2.2/1-2.2:1.0/0003:03F0:0024.0001/input/input4/event4"
[ 21.571] (II) XINPUT: Adding extended input device "CHICONY HP Basic USB Keyboard" (type: KEYBOARD, id 6)
[ 21.571] (**) Option "xkb_rules" "evdev"
[ 21.571] (**) Option "xkb_model" "pc105"
[ 21.571] (**) Option "xkb_layout" "us"
[ 21.572] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/event5)
[ 21.572] (**) USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[ 21.572] (II) Using input driver 'evdev' for 'USB Optical Mouse'
[ 21.572] (**) USB Optical Mouse: always reports core events
[ 21.572] (**) evdev: USB Optical Mouse: Device: "/dev/input/event5"
[ 21.628] (--) evdev: USB Optical Mouse: Vendor 0x1bcf Product 0x7
[ 21.628] (--) evdev: USB Optical Mouse: Found 3 mouse buttons
[ 21.628] (--) evdev: USB Optical Mouse: Found scroll wheel(s)
[ 21.628] (--) evdev: USB Optical Mouse: Found relative axes
[ 21.628] (--) evdev: USB Optical Mouse: Found x and y relative axes
[ 21.628] (--) evdev: USB Optical Mouse: Found absolute axes
[ 21.628] (II) evdev: USB Optical Mouse: Forcing absolute x/y axes to exist.
[ 21.628] (II) evdev: USB Optical Mouse: Configuring as mouse
[ 21.628] (II) evdev: USB Optical Mouse: Adding scrollwheel support
[ 21.628] (**) evdev: USB Optical Mouse: YAxisMapping: buttons 4 and 5
[ 21.628] (**) evdev: USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 21.628] (**) Option "config_info" "udev:/sys/devices/3530000.xhci/usb1/1-2/1-2.3/1-2.3:1.0/0003:1BCF:0007.0002/input/input5/event5"
[ 21.628] (II) XINPUT: Adding extended input device "USB Optical Mouse" (type: MOUSE, id 7)
[ 21.628] (II) evdev: USB Optical Mouse: initialized for relative axes.
[ 21.628] (WW) evdev: USB Optical Mouse: ignoring absolute axes.
[ 21.628] (**) USB Optical Mouse: (accel) keeping acceleration scheme 1
[ 21.628] (**) USB Optical Mouse: (accel) acceleration profile 0
[ 21.628] (**) USB Optical Mouse: (accel) acceleration factor: 2.000
[ 21.628] (**) USB Optical Mouse: (accel) acceleration threshold: 4
[ 21.629] (II) config/udev: Adding input device gpio-keys (/dev/input/event3)
[ 21.629] (**) gpio-keys: Applying InputClass "evdev keyboard catchall"
[ 21.629] (II) Using input driver 'evdev' for 'gpio-keys'
[ 21.629] (**) gpio-keys: always reports core events
[ 21.629] (**) evdev: gpio-keys: Device: "/dev/input/event3"
[ 21.629] (--) evdev: gpio-keys: Vendor 0x1 Product 0x1
[ 21.629] (--) evdev: gpio-keys: Found keys
[ 21.629] (II) evdev: gpio-keys: Configuring as keyboard
[ 21.629] (**) Option "config_info" "udev:/sys/devices/gpio-keys/input/input3/event3"
[ 21.629] (II) XINPUT: Adding extended input device "gpio-keys" (type: KEYBOARD, id 8)
[ 21.629] (**) Option "xkb_rules" "evdev"
[ 21.629] (**) Option "xkb_model" "pc105"
[ 21.629] (**) Option "xkb_layout" "us"
[ 21.630] (II) config/udev: Adding input device tegra-snd-t186ref-mobile-rt565x Headphone Jack (/dev/input/event2)
[ 21.630] (**) tegra-snd-t186ref-mobile-rt565x Headphone Jack: Applying InputClass "evdev keyboard catchall"
[ 21.630] (II) Using input driver 'evdev' for 'tegra-snd-t186ref-mobile-rt565x Headphone Jack'
[ 21.630] (**) tegra-snd-t186ref-mobile-rt565x Headphone Jack: always reports core events
[ 21.630] (**) evdev: tegra-snd-t186ref-mobile-rt565x Headphone Jack: Device: "/dev/input/event2"
[ 21.630] (--) evdev: tegra-snd-t186ref-mobile-rt565x Headphone Jack: Vendor 0 Product 0
[ 21.630] (--) evdev: tegra-snd-t186ref-mobile-rt565x Headphone Jack: Found keys
[ 21.630] (II) evdev: tegra-snd-t186ref-mobile-rt565x Headphone Jack: Configuring as keyboard
[ 21.630] (**) Option "config_info" "udev:/sys/devices/sound/sound/card1/input2/event2"
[ 21.631] (II) XINPUT: Adding extended input device "tegra-snd-t186ref-mobile-rt565x Headphone Jack" (type: KEYBOARD, id 9)
[ 21.631] (**) Option "xkb_rules" "evdev"
[ 21.631] (**) Option "xkb_model" "pc105"
[ 21.631] (**) Option "xkb_layout" "us"
