alive
April 23, 2023, 10:47am
1
I want to use the type-c interface in custom carrier boart as the device mode, In this way, i can through pc get orin nx’s data. now i can use micro usb into device mode, and i want to know, whether i can set type-c who support usb3.0 mode into deivce mode.
in custom carrier boart have 3 type-c interface, usb3-0 ~ usb3-2.
xusb_padctl: xusb_padctl@3520000 {
status = "okay";
pads {
usb2 {
lanes {
usb2-0 {
nvidia,function = "xusb";
status = "okay";
usb2-1 {
status = "okay";
usb2-2 {
status = "okay";
usb3 {
lanes {
usb3-0 {
status = "okay";
usb3-1 {
status = "okay";
usb3-2 {
status = "okay";
ports {
usb2-0 {
mode = "peripheral";
status = "okay";
vbus-supply = <&p3509_vdd_5v_sys>;
#if TEGRA_XUSB_DT_VERSION >= DT_VERSION_3
usb-role-switch;
connector {
compatible = "usb-b-connector", "gpio-usb-b-connector";
label = "micro-USB";
type = "micro";
vbus-gpio = <USB_ROLE_DEVICE>;
cable-connected-on-boot = <USB_ROLE_DEVICE>;
#endif
usb2-1 {
mode = "host";
vbus-supply = <&p3509_vdd_av10_hub>;
status = "okay";
usb2-2 {/* Goes to M2.E */
mode = "host";
status = "okay";
usb3-0 {
status = "okay";
nvidia,usb2-companion = <1>;
usb3-1 {
status = "okay";
usb3-2 {
status = "okay";
tegra_xudc: xudc@3550000 {
status = "okay";
phys = <&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-0}>;
phy-names = "usb2-0";
nvidia,xusb-padctl = <&xusb_padctl>;
tegra_xhci: xhci@3610000 {
status = "okay";
nvidia,use-typec-switch;
phys = <&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-1}>,
<&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-2}>,
<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-0}>,
<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-1}>,
<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-2}>;
phy-names = "usb2-1", "usb2-2", "usb3-0","usb3-1", "usb3-2";
alive
April 23, 2023, 11:13am
2
I have gained some information on other topics, and I have done similar things, but unfortunately, it still doesn’t work.
status = "okay";
pads {
usb2 {
lanes {
usb2-0 {
status = "okay";
usb2-1 {
status = "okay";
usb2-2 {
status = "okay";
usb3 {
lanes {
usb3-0 {
status = "okay";
usb3-1 {
status = "okay";
usb3-2 {
status = "okay";
ports {
usb2-0 {
status = "okay";
usb-role-switch;
connector {
type = "micro";
#endif
usb2-1 {
mode = "host";
status = "okay";
mode = "host";
status = "okay";
usb3-0 {
status = "okay";
dr_mode = "peripheral";
usb3-1 {
status = "okay";
usb3-2 {
status = "okay";
status = "okay";
phys = <&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-0}>,
<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-0}>;
phy-names = "usb2-0", "usb3-0";
status = "okay";
phy-names = "usb2-1", "usb2-2", "usb3-1", "usb3-2";
What kind of type C controller is your custom board using for the type C interface?
Any schematic to share?
Have you checked the adaptation guide document?
alive
April 24, 2023, 5:46am
5
the controller is ti s3200, and the designer of the customized board told me that the design of the board was based on the official documentation.
Why all the nvidia,usb2-companion is same on your device tree?
This should match the hardware usb2 port. Did you read the document or you don’t know what I am talking about?
alive
April 24, 2023, 7:32am
7
I’m sorry, as a beginner in this field, I did not configure the device tree correctly.Can you give me some advice!
I want to make usb3-1 enter device mode, as a mass storage container accessed by a PC. Any document can help me solve this problem?
alive
April 24, 2023, 8:55am
9
i had read the section you remind, and follow the schematic,i had changed the dts part like this
status = "okay";
pads {
usb2 {
lanes {
usb2-0 {
status = "okay";
usb2-1 {
status = "okay";
usb2-3 {
status = "okay";
usb2-4 {
status = "okay";
usb3 {
lanes {
usb3-0 {
status = "okay";
usb3-1 {
status = "okay";
usb3-2 {
status = "okay";
ports {
usb2-0 {
status = "okay";
usb-role-switch;
connector {
type = "micro";
#endif
usb2-1 {
mode = "host";
status = "okay";
usb2-3 {
mode = "host";
status = "okay";
usb2-4 {
mode = "host";
status = "okay";
usb3-0 {
status = "okay";
usb3-1 {
nvidia,usb2-companion = <4>;
status = "okay";
usb3-2 {
nvidia,usb2-companion = <3>;
status = "okay";
status = "okay";
phy-names = "usb2-0", "usb3-2";
status = "okay";
<&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-3}>,
<&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-4}>,
<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-1}>;
phy-names = "usb2-1", "usb2-3", "usb2-4", "usb3-0", "usb3-1";
What is the exact usb port that you want to set it as device mode?
Your device tree seems having conflict with it.
xudc driver says usb2-0, usb3-2. But your previous setting indicates usb3-2 is not a pair with usb2-0 at all.
alive
April 24, 2023, 9:06am
11
i want to usb3-2 port as device mode, so i should let usb3-2 pair with usb2-0?
like this?
usb3-2 {
nvidia,usb2-companion = <0>;
status = "okay";
You should check your hardware schematic but not ask me.
alive
April 24, 2023, 9:22am
13
my mistake, so according to schematic, i should let usb2-3 enter peripheral mode right?
like this:
ports {
usb2-0 {
status = "disable";
usb-role-switch;
connector {
type = "micro";
#endif
usb2-1 {
mode = "host";
status = "okay";
usb2-3 {
status = "okay";
usb-role-switch;
connector {
compatible = "usb-c-connector";
label = "USB-C";
#endif
usb2-4 {
mode = "host";
status = "okay";
usb3-0 {
status = "okay";
usb3-1 {
status = "okay";
usb3-2 {
status = "okay";
status = "okay";
phys = <&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-3}>,
phy-names = "usb2-3", "usb3-2";
status = "okay";
phy-names = "usb2-1", "usb2-4", "usb3-0", "usb3-1";
and please disable usb ports which are not present in the schematic.
Please also refer to the kernel/kernel-5.10/Documentation/devicetree/bindings/connector/usb-connector.yaml as the document indicates.
This file is in the kernel public source code.
alive
April 24, 2023, 10:28am
16
the specified port usb3-2 is still host mode, what i change file is kernel-dts/cvb/tegra234-p3509-a02.dtsi.
ports {
usb2-0 {
status = "disabled";
usb-role-switch;
connector {
type = "micro";
#endif
usb2-1 {
mode = "host";
usb2-3 {
status = "okay";
usb-role-switch;
connector {
label = "USB-C";
data-role = "device";
#endif
usb2-4 {
mode = "host";
status = "okay";
usb3-0 {
usb3-1 {
status = "okay";
usb3-2 {
status = "okay";
status = "okay";
Are you able to tell if your dtb change is taking effect? or you don’t know how to check?
alive
April 24, 2023, 11:54am
18
I use a type-c cable to connect to the pc, and I can’t see the relevant nodes through the lsusb command, and I connect the keyboard to the interface, and it still works.
No, I mean are you able to tell if your dtb is really updated to you devcie.
請問這句有看不懂的地方嗎
alive
April 24, 2023, 11:57am
20
I checked it with dtc decompilation, the nodes in the device are indeed updated
Could you share your dmesg?
