I check the documents ,such as datasheet, Product Design Guide, and Jetson_AGX_Xavier_Series_Pin_Descriptions.xlsx.
It says “Standby Request. Requests module enter standby (SC7 state). A 10kΩ pull-up to 1.8V is
present on the module.”
So, is it possible just to set the STANDBY_REQ_N(L11) pin to the Low level in order to put the AGX Xavier in standby?
In addition, is it possible just to set the STANDBY_REQ_N(L11) pin to the High level in order to go back to on state?
thanks
