How to turn off the PCIe attribute noSnoop for geforce 3070 in windows/linux?
We found that the Nvidia geforce driver turn on the PCIe attribute noSnoop for RTX 3070 in windows and linux, like windows11 with11th Gen Intel® Core™ i7-11700K @ 3.60GHz × 16, windows 11with12th Gen Intel(R) Core™ i7-12700 2.10 GHz, linux with 12th Gen Intel(R) Core™ i7-12700K.
Whether Nvidia currently provides configuration options on windows and linux systems to disable nosnoop permanently at the Nvidia driver level, for example like modifying windows registry or Nvidia config file?
the config space like:
$sudo lspci -vvv -xxxx -s 01:00.0
01:00.0 VGA compatible controller: NVIDIA Corporation Device 2488 (rev a1) (prog-if 00 [VGA controller])
Subsystem: Dell Device c903
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 154
Region 0: Memory at 71000000 (32-bit, non-prefetchable) [size=16M]
Region 1: Memory at 6000000000 (64-bit, prefetchable) [size=256M]
Region 3: Memory at 6010000000 (64-bit, prefetchable) [size=32M]
Region 5: I/O ports at 3000 [size=128]
Expansion ROM at 72080000 [virtual] [disabled] [size=512K]
Capabilities: [60] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fee00678 Data: 0000
Capabilities: [78] Express (v2) Legacy Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 <64us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+
DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+ FLReset-
MaxPayload 256 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 16GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <1us, L1 <4us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM L1 Enabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 16GT/s (ok), Width x16 (ok)
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range AB, TimeoutDis+, NROPrPrP-, LTR+
10BitTagComp+, 10BitTagReq+, OBFF Via message, ExtFmt-, EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled
AtomicOpsCtl: ReqEn-
LnkCtl2: Target Link Speed: 16GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+, EqualizationPhase1+
EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest-
Capabilities: [b4] Vendor Specific Information: Len=14 <?> Capabilities: [100 v1] Virtual Channel Caps: LPEVC=0 RefClk=100ns PATEntryBits=1 Arb: Fixed- WRR32- WRR64- WRR128- Ctrl: ArbSelect=Fixed Status: InProgress- VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans- Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256- Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff Status: NegoPending- InProgress- Capabilities: [250 v1] Latency Tolerance Reporting Max snoop latency: 34326183936ns Max no snoop latency: 34326183936ns Capabilities: [258 v1] L1 PM Substates L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+ PortCommonModeRestoreTime=255us PortTPowerOnTime=10us L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1- T_CommonMode=0us LTR1.2_Threshold=281600ns L1SubCtl2: T_PwrOn=10us Capabilities: [128 v1] Power Budgeting <?>
Capabilities: [420 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
AERCap: First Error Pointer: 00, ECRCGenCap- ECRCGenEn- ECRCChkCap- ECRCChkEn-
MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
HeaderLog: 00000000 00000000 00000000 00000000
Capabilities: [600 v1] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?> Capabilities: [900 v1] Secondary PCI Express LnkCtl3: LnkEquIntrruptEn-, PerformEqu- LaneErrStat: 0 Capabilities: [bb0 v1] Resizable BAR <?>
Capabilities: [c1c v1] Physical Layer 16.0 GT/s <?> Capabilities: [d00 v1] Lane Margining at the Receiver <?>
Capabilities: [e00 v1] Data Link Feature <?>
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
00: de 10 88 24 07 04 10 00 a1 00 00 03 00 00 80 00
10: 00 00 00 71 0c 00 00 00 60 00 00 00 0c 00 00 10
20: 60 00 00 00 01 30 00 00 00 00 00 00 28 10 03 c9
30: 00 00 00 00 60 00 00 00 00 00 00 00 ff 01 00 00
40: 28 10 03 c9 00 00 00 00 00 00 00 00 00 00 00 00
50: 00 00 00 00 01 00 00 00 ce d6 23 00 00 00 00 00
60: 01 68 03 48 08 00 00 00 05 78 81 00 78 06 e0 fe
70: 00 00 00 00 00 00 00 00 10 b4 12 00 e1 8d 2c 11
80: 30 29 00 00 04 4d 45 00 42 01 04 11 00 00 00 00
90: 00 00 00 00 00 00 00 00 00 00 00 00 13 08 07 00
a0: 00 04 00 00 1e 00 80 01 04 00 1e 00 00 00 00 00
b0: 00 00 00 00 09 00 14 01 01 00 13 0b 80 00 00 00
c0: 44 8c f6 42 00 00 00 00 11 00 05 00 00 00 b9 00
d0: 00 00 ba 00 00 00 00 00 00 00 00 00 00 00 00 00
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
