uname -a
Summary
Linux andrew-Nitro-N50-600 6.2.0-32-generic #32~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Fri Aug 18 10:40:13 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
lsb_release -a
Summary
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.3 LTS
Release: 22.04
Codename: jammy
NVIDIA GeForce RTX 2060
NVIDIA Driver Version: 535.86.05
/var/log/kern.log :
Summary
> Aug 28 23:38:17 andrew-Nitro-N50-600 kernel: [346641.255824] snd_hda_intel 0000:00:1f.3: Unstable LPIB (345592 >= 176400); disabling LPIB delay counting
> Aug 28 23:38:18 andrew-Nitro-N50-600 kernel: [346642.105270] NVRM: Xid (PCI:0000:01:00): 79, pid='<unknown>', name=<unknown>, GPU has fallen off the bus.
> Aug 28 23:38:18 andrew-Nitro-N50-600 kernel: [346642.105275] NVRM: GPU 0000:01:00.0: GPU has fallen off the bus.
> Aug 28 23:38:18 andrew-Nitro-N50-600 kernel: [346642.105516] NVRM: A GPU crash dump has been created. If possible, please run
> Aug 28 23:38:18 andrew-Nitro-N50-600 kernel: [346642.105516] NVRM: nvidia-bug-report.sh as root to collect this data before
> Aug 28 23:38:18 andrew-Nitro-N50-600 kernel: [346642.105516] NVRM: the NVIDIA kernel module is unloaded.
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828808] irq 17: nobody cared (try booting with the "irqpoll" option)
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828813] CPU: 2 PID: 0 Comm: swapper/2 Tainted: P O 6.2.0-32-generic #32~22.04.1-Ubuntu
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828816] Hardware name: Acer Nitro N50-600/Nitro N50-600, BIOS R01-C2 04/16/2019
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828817] Call Trace:
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828819] <IRQ>
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828821] dump_stack_lvl+0x48/0x70
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828824] dump_stack+0x10/0x20
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828826] __report_bad_irq+0x30/0xd0
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828829] note_interrupt+0x2f9/0x350
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828830] ? eoi_ioapic_pin+0xe4/0x130
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828833] handle_irq_event+0x79/0x80
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828835] handle_fasteoi_irq+0x7d/0x1d0
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828837] __common_interrupt+0x4f/0x110
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828839] common_interrupt+0x9f/0xb0
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828841] </IRQ>
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828842] <TASK>
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828843] asm_common_interrupt+0x27/0x40
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828845] RIP: 0010:cpuidle_enter_state+0xde/0x6f0
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828848] Code: 79 11 59 e8 a4 34 45 ff 8b 53 04 49 89 c7 0f 1f 44 00 00 31 ff e8 52 13 44 ff 80 7d d0 00 0f 85 e8 00 00 00 fb 0f 1f 44 00 00 <45> 85 f6 0f 88 0f 02 00 00 4d 63 ee 49 83 fd 09 0f 87 c4 04 00 00
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828850] RSP: 0018:ffffa82140113e28 EFLAGS: 00000246
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828852] RAX: 0000000000000000 RBX: ffffc8213fc80000 RCX: 0000000000000000
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828853] RDX: 0000000000000002 RSI: 0000000000000000 RDI: 0000000000000000
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828854] RBP: ffffa82140113e78 R08: 0000000000000000 R09: 0000000000000000
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828855] R10: 0000000000000000 R11: 0000000000000000 R12: ffffffffa86c2840
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828856] R13: 0000000000000001 R14: 0000000000000001 R15: 00013b4512acb040
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828859] ? cpuidle_enter_state+0xce/0x6f0
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828862] cpuidle_enter+0x2e/0x50
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828864] cpuidle_idle_call+0x14f/0x1e0
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828867] do_idle+0x82/0x110
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828869] cpu_startup_entry+0x20/0x30
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828871] start_secondary+0x122/0x160
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828874] secondary_startup_64_no_verify+0xe5/0xeb
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828878] </TASK>
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828878] handlers:
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828880] [<00000000763f98cf>] azx_interrupt [snd_hda_codec]
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.828895] Disabling IRQ #17
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843112] irq 16: nobody cared (try booting with the "irqpoll" option)
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843117] CPU: 2 PID: 0 Comm: swapper/2 Tainted: P O 6.2.0-32-generic #32~22.04.1-Ubuntu
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843119] Hardware name: Acer Nitro N50-600/Nitro N50-600, BIOS R01-C2 04/16/2019
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843121] Call Trace:
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843122] <IRQ>
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843124] dump_stack_lvl+0x48/0x70
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843128] dump_stack+0x10/0x20
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843130] __report_bad_irq+0x30/0xd0
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843133] note_interrupt+0x2f9/0x350
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843134] ? eoi_ioapic_pin+0xe4/0x130
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843137] handle_irq_event+0x79/0x80
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843139] handle_fasteoi_irq+0x7d/0x1d0
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843141] __common_interrupt+0x4f/0x110
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843143] common_interrupt+0x9f/0xb0
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843145] </IRQ>
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843146] <TASK>
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843147] asm_common_interrupt+0x27/0x40
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843149] RIP: 0010:cpuidle_enter_state+0xde/0x6f0
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843152] Code: 79 11 59 e8 a4 34 45 ff 8b 53 04 49 89 c7 0f 1f 44 00 00 31 ff e8 52 13 44 ff 80 7d d0 00 0f 85 e8 00 00 00 fb 0f 1f 44 00 00 <45> 85 f6 0f 88 0f 02 00 00 4d 63 ee 49 83 fd 09 0f 87 c4 04 00 00
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843154] RSP: 0018:ffffa82140113e28 EFLAGS: 00000246
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843156] RAX: 0000000000000000 RBX: ffffc8213fc80000 RCX: 0000000000000000
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843157] RDX: 0000000000000002 RSI: 0000000000000000 RDI: 0000000000000000
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843158] RBP: ffffa82140113e78 R08: 0000000000000000 R09: 0000000000000000
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843159] R10: 0000000000000000 R11: 0000000000000000 R12: ffffffffa86c2840
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843160] R13: 0000000000000001 R14: 0000000000000001 R15: 00013b451386fa90
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843164] ? cpuidle_enter_state+0xce/0x6f0
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843166] cpuidle_enter+0x2e/0x50
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843168] cpuidle_idle_call+0x14f/0x1e0
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843171] do_idle+0x82/0x110
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843173] cpu_startup_entry+0x20/0x30
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843175] start_secondary+0x122/0x160
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843178] secondary_startup_64_no_verify+0xe5/0xeb
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843182] </TASK>
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843182] handlers:
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843183] [<00000000ad9fdde8>] i801_isr [i2c_i801]
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346642.843190] Disabling IRQ #16
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346643.016641] audit: type=1107 audit(1693255099.623:2030): pid=1152 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_method_call" bus="system" path="/org/freedesktop/NetworkManager" interface="org.freedesktop.NetworkManager" member="GetDevices" mask="send" name="org.freedesktop.NetworkManager" pid=1677006 label="snap.firefox.firefox" peer_pid=1154 peer_label="unconfined"
> Aug 28 23:38:19 andrew-Nitro-N50-600 kernel: [346643.016641] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
> Aug 28 23:38:28 andrew-Nitro-N50-600 kernel: [346652.262761] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:6:0:0x0000000f
> Aug 28 23:38:28 andrew-Nitro-N50-600 kernel: [346652.262769] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:4:0:0x0000000f
> Aug 28 23:38:30 andrew-Nitro-N50-600 kernel: [346654.267943] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:6:0:0x0000000f
> Aug 28 23:38:30 andrew-Nitro-N50-600 kernel: [346654.267951] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:4:0:0x0000000f
> Aug 28 23:38:30 andrew-Nitro-N50-600 kernel: [346654.271939] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:6:0:0x0000000f
> Aug 28 23:38:30 andrew-Nitro-N50-600 kernel: [346654.271949] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:4:0:0x0000000f
> Aug 28 23:38:40 andrew-Nitro-N50-600 kernel: [346664.272163] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:6:0:0x0000000f
> Aug 28 23:38:40 andrew-Nitro-N50-600 kernel: [346664.272171] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:4:0:0x0000000f
> Aug 28 23:38:40 andrew-Nitro-N50-600 kernel: [346664.273117] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:6:0:0x0000000f
> Aug 28 23:38:40 andrew-Nitro-N50-600 kernel: [346664.273124] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:4:0:0x0000000f
> Aug 28 23:38:40 andrew-Nitro-N50-600 kernel: [346664.273195] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:6:0:0x0000000f
> Aug 28 23:38:40 andrew-Nitro-N50-600 kernel: [346664.273200] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:4:0:0x0000000f
> Aug 28 23:38:40 andrew-Nitro-N50-600 kernel: [346664.273316] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:6:0:0x0000000f
> Aug 28 23:38:40 andrew-Nitro-N50-600 kernel: [346664.273321] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:4:0:0x0000000f
> Aug 28 23:38:40 andrew-Nitro-N50-600 kernel: [346664.275989] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:6:0:0x0000000f
> Aug 28 23:38:40 andrew-Nitro-N50-600 kernel: [346664.275996] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:4:0:0x0000000f
> Aug 28 23:38:40 andrew-Nitro-N50-600 kernel: [346664.289509] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:6:0:0x0000000f
> Aug 28 23:38:40 andrew-Nitro-N50-600 kernel: [346664.289517] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:4:0:0x0000000f
> Aug 28 23:38:40 andrew-Nitro-N50-600 kernel: [346664.302256] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:6:0:0x0000000f
> Aug 28 23:38:40 andrew-Nitro-N50-600 kernel: [346664.302265] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:4:0:0x0000000f
> Aug 28 23:39:32 andrew-Nitro-N50-600 kernel: [ 0.000000] microcode: microcode updated early to revision 0xf4, date = 2023-02-23
> Aug 28 23:39:32 andrew-Nitro-N50-600 kernel: [ 0.000000] Linux version 6.2.0-32-generic (buildd@lcy02-amd64-076) (x86_64-linux-gnu-gcc-11 (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #32~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Fri Aug 18 10:40:13 UTC 2 (Ubuntu 6.2.0-32.32~22.04.1-generic 6.2.16)
> Aug 28 23:39:32 andrew-Nitro-N50-600 kernel: [ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.2.0-32-generic root=UUID=07364ede-0113-48a3-bd9b-e59f3edc56fc ro quiet splash vt.handoff=7
