I am having a lot of trouble installing my GTX 1650 TI under Pop_OS! 21.04.
I’ve tried everything I could find scattered around this forum and on google as well, but to no avail.
I’ll drop some info about my current system:
neofetch:
///////767//////////////// OS: Pop!_OS 21.04 x86_64
//////7676767676////////////// Host: HP Pavilion Gaming Laptop 15-ec
/////76767//7676767////////////// Kernel: 5.8.0-7642-generic
/////767676///76767/////////////// Uptime: 15 mins
///////767676///76767.///7676/////// Packages: 2448 (dpkg), 45 (flatpak)
/////////767676//76767///767676//////// Shell: bash 5.1.4
//////////76767676767////76767///////// Resolution: 1920x1080
///////////76767676//////7676////////// DE: GNOME
////////////,7676,///////767/////////// WM: Mutter
/////////////*7676///////76//////////// WM Theme: Pop
///////////////7676//////////////////// Theme: Pop-dark [GTK2/3]
///////////////7676///767//////////// Icons: Pop [GTK2/3]
//////////////////////’//////////// Terminal: gnome-terminal
//////.7676767676767676767,////// CPU: AMD Ryzen 5 4600H with Radeon Gr
/////767676767676767676767///// GPU: AMD ATI 05:00.0 Renoir
/////////////////////////// Memory: 2155MiB / 31532MiB
GPU only shows AMD ATI Renoir (onboard graphics), missing GeForce GTX 1650 TI.
nvidia-smi:
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
I’ve tried installing the driver per system76 recommendation,
sudo apt install system76-driver-nvidia
… errors while processing:
system76-io-dkms
system76-driver
system76-acpi-dkms
system76-dkms
nvidia-dkms-470
nvidia-driver-470
nvidia-driver-460
and also installing the driver downloaded from Nvidia website, sudo ./NVIDIA-Linux-x86_64-430.09.run
and I get a message stating:
*WARNING: You do not appear to have an NVIDIA GPU supported by the 430.09 NVIDIA Linux graphics driver installed in this system. For further details, please see the appendix SUPPORTED *
NVIDIA GRAPHICS CHIPS in the README available on the Linux driver download page at www.nvidia.com.*
I am desperate trying to find a solution to this, as my discrete graphics card is not working.
I have secure boot disabled under the BIOS.
Sounds like the nvidia gpu isn’t detected at all. In case this is a notebook, please check whether it’s diabled in bios.
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
Please find attached the request file with the report.
By the way, I forgot to mention two things. This is a dual boot machine, with windows 10 on the other side, and the graphic card works under windows, every time. The other thing is that the graphic card worked in the past under linux. I could switch between Integrated graphics,Intel graphics, Hybrid graphics or Compute graphics. I cannot find anything in the BIOS that enables or disables the graphic card.
Created file blacklist-nouveau-nvidiafb.conf and added both lines.
Output of update-initramfs -u:
update-initramfs: Generating /boot/initrd.img-5.15.5-76051505-generic
W: Possible missing firmware /lib/firmware/amdgpu/yellow_carp_gpu_info.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vangogh_gpu_info.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_ta.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_sos.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_mec2.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_mec.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/cyan_skillfish2_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/cyan_skillfish2_mec2.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/cyan_skillfish2_mec.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/cyan_skillfish2_me.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/cyan_skillfish2_pfp.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/cyan_skillfish2_ce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/cyan_skillfish_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/cyan_skillfish_mec2.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/cyan_skillfish_mec.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/cyan_skillfish_me.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/cyan_skillfish_pfp.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/cyan_skillfish_ce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_sdma.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/cyan_skillfish2_sdma1.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/cyan_skillfish2_sdma.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/cyan_skillfish_sdma1.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/cyan_skillfish_sdma.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/sienna_cichlid_mes.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/navi10_mes.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_vcn.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_smc.bin for module amdgpu
kernelstub.Config : INFO Looking for configuration…
kernelstub : INFO System information:
kernelstub.Installer : INFO Copying Kernel into ESP
kernelstub.Installer : INFO Copying initrd.img into ESP
kernelstub.Installer : INFO Setting up loader.conf configuration
kernelstub.Installer : INFO Making entry file for Pop!_OS
kernelstub.Installer : INFO Backing up old kernel
UNIT LOAD ACTIVE SUB DESCRIPTION
accounts-daemon.service loaded active running Accounts Service
acpid.service loaded active running ACPI event daemon
alsa-restore.service loaded active exited Save/Restore Sound Card State
anydesk.service loaded active running AnyDesk
apache2.service loaded active running The Apache HTTP Server
apparmor.service loaded active exited Load AppArmor profiles
apport.service loaded active exited LSB: automatic crash report generation
atd.service loaded active running Deferred execution scheduler
atop.service loaded active running Atop advanced performance monitor
atopacct.service loaded active running Atop process accounting daemon
avahi-daemon.service loaded active running Avahi mDNS/DNS-SD Stack
blk-availability.service loaded active exited Availability of block devices
bluetooth.service loaded active running Bluetooth service
colord.service loaded active running Manage, Install and Generate Color Profiles
console-setup.service loaded active exited Set console font and keymap
cron.service loaded active running Regular background program processing daemon
cups-browsed.service loaded active running Make remote CUPS printers available locally
cups.service loaded active running CUPS Scheduler
dbus.service loaded active running D-Bus System Message Bus
finalrd.service loaded active exited Create final runtime dir for shutdown pivot root
fwupd.service loaded active running Firmware update daemon
gdm.service loaded active running GNOME Display Manager
geoclue.service loaded active running Location Lookup Service
grub-common.service loaded active exited Record successful boot for GRUB
hddtemp.service loaded active exited LSB: disk temperature monitoring daemon
ifupdown-pre.service loaded active exited Helper to synchronize boot up for ifupdown
irqbalance.service loaded active running irqbalance daemon
keyboard-setup.service loaded active exited Set the console keyboard layout
kmod-static-nodes.service loaded active exited Create list of static device nodes for the current kernel
lm-sensors.service loaded active exited Initialize hardware monitoring sensors
lvm2-monitor.service loaded active exited Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling
mariadb.service loaded active running MariaDB 10.5.12 database server
ModemManager.service loaded active running Modem Manager
networkd-dispatcher.service loaded active running Dispatcher daemon for systemd-networkd
networking.service loaded active exited Raise network interfaces
NetworkManager-wait-online.service loaded active exited Network Manager Wait Online
NetworkManager.service loaded active running Network Manager
openvpn.service loaded active exited OpenVPN service
packagekit.service loaded active running PackageKit Daemon
plymouth-quit-wait.service loaded active exited Hold until boot process finishes up
plymouth-read-write.service loaded active exited Tell Plymouth To Write Out Runtime Data
plymouth-start.service loaded active exited Show Plymouth Boot Screen
polkit.service loaded active running Authorization Manager
pop-upgrade.service loaded active running Pop Upgrade Daemon
postfix.service loaded active exited Postfix Mail Transport Agent
postfix@-.service loaded active running Postfix Mail Transport Agent (instance -)
resilio-sync.service loaded active running Resilio Sync service
resolvconf.service loaded active exited Nameserver information manager
rsyslog.service loaded active running System Logging Service
rtkit-daemon.service loaded active running RealtimeKit Scheduling Policy Service
setvtrgb.service loaded active exited Set console scheme
switcheroo-control.service loaded active running Switcheroo Control Proxy service
system76-firmware-daemon.service loaded active running System76 Firmware Daemon
system76-power.service loaded active running System76 Power Daemon
systemd-backlight@backlight:amdgpu_bl0.service loaded active exited Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0
systemd-journal-flush.service loaded active exited Flush Journal to Persistent Storage
systemd-journald.service loaded active running Journal Service
systemd-logind.service loaded active running User Login Management
systemd-modules-load.service loaded active exited Load Kernel Modules
systemd-random-seed.service loaded active exited Load/Save Random Seed
systemd-remount-fs.service loaded active exited Remount Root and Kernel File Systems
systemd-resolved.service loaded active running Network Name Resolution
systemd-sysctl.service loaded active exited Apply Kernel Variables
systemd-sysusers.service loaded active exited Create System Users
systemd-timesyncd.service loaded active running Network Time Synchronization
systemd-tmpfiles-setup-dev.service loaded active exited Create Static Device Nodes in /dev
systemd-tmpfiles-setup.service loaded active exited Create Volatile Files and Directories
systemd-udev-trigger.service loaded active exited Coldplug All udev Devices
systemd-udevd.service loaded active running Rule-based Manager for Device Events and Files
systemd-update-utmp.service loaded active exited Update UTMP about System Boot/Shutdown
systemd-user-sessions.service loaded active exited Permit User Sessions
touchegg.service loaded active running Touchégg Daemon
udisks2.service loaded active running Disk Manager
ufw.service loaded active exited Uncomplicated firewall
upower.service loaded active running Daemon for power management
user-runtime-dir@1000.service loaded active exited User Runtime Directory /run/user/1000
user@1000.service loaded active running User Manager for UID 1000
wpa_supplicant.service loaded active running WPA supplicant
dez 02 11:39:02 pavy system76-power[753]: [INFO] 0000:01:00.0: NVIDIA graphics
dez 02 11:39:02 pavy system76-power[753]: [INFO] 0000:01:00.0: Function for 0000:01:00.0
dez 02 11:39:02 pavy system76-power[753]: [INFO] 0000:01:00.1: Function for 0000:01:00.0
and also:
dez 02 11:39:03 pavy optimus.desktop[1399]: Could not find provider with name NVIDIA-0
dez 02 11:39:10 pavy nvidia-settings-autostart.desktop[3727]: ERROR: NVIDIA driver is not loaded
dez 02 11:39:10 pavy nvidia-settings-autostart.desktop[3727]: ERROR: Unable to load info from any available system
So I guess something is failing, but I don’t know exactly what, because in a way I am also not sure what to look for in this output. Could you guys please help me further?
I’ll leave the full output in a file here, just in case. journalctlb0.txt (421.7 KB)
I have the same problem using a similar configuration:
(neofetch)
//////7676767676////////////// Host: Nitro AN515-44 V1.01
/////76767//7676767////////////// Kernel: 5.15.5-76051505-generic
/////767676///76767/////////////// Uptime: 2 hours, 11 mins
///////767676///76767.///7676/////// Packages: 2694 (dpkg), 30 (flatpak), 9 (snap)
///////////76767676//////7676////////// DE: GNOME 3.38.4
///////////////7676//////////////////// Theme: Pop [GTK2/3]
//////////////////////’//////////// Terminal: x-terminal-emul
//////.7676767676767676767,////// CPU: AMD Ryzen 7 4800H with Radeon Graphics (16) @ 2.900GHz
/////////////////////////// Memory: 7156MiB / 31533MiB
Video: also GeForce GTX 1650 TI
I have hunted some fw files but cannot get the following ones.
$sudo update-initramfs -u -k all
cryptsetup: WARNING: Resume target cryptswap uses a key file
kernelstub.Config : INFO Looking for configuration...
OS:..................Pop!_OS 21.04
Root partition:....../dev/dm-1
Root FS UUID:........cbf51df0-0f8e-4291-af15-7a2cbdbf1ea0
ESP Path:............/boot/efi
ESP Partition:......./dev/nvme0n1p1
ESP Partition #:.....1
NVRAM entry #:.......-1
Boot Variable #:.....0000
Kernel Boot Options:.quiet loglevel=0 systemd.show_status=false splash
Kernel Image Path:.../boot/vmlinuz-5.15.5-76051505-generic
Initrd Image Path:.../boot/initrd.img-5.15.5-76051505-generic
Force-overwrite:.....False
Generix,
I would like to thank you for your time and patience in helping me solving this issue. You already helped me a lot.
I’ve just opened an issue where you suggested and I hope they eventually give me a solution for this problem.
If I ever find out the solution, I will also post it here for future readers.
