Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.6.0.8170
1.5.1.7815
1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
other
Hi all:
we try to develop some linux drivers, so the xavier need to be flashed with updated dtb and kernel.
we run below command to update dtb:
sudo ./bootburn.sh -b e3550b03-t194b -u B_1_kernel B_1_kernel-dtb B_1_ramdisk -x /dev/ttyUSB3
script return success,but xavier B still uses the old dtb.(changed 'b’to ‘a’, ‘B’ to ‘A’, to flash xavier A,this command works well)
we changed command to flash all images for xavierB:
sudo ./bootburn.sh -b e3550b03-t194b -x /dev/ttyUSB3
this command works well,dtb updated as expected.
someone who has the same problem:Easier way to flash Xavier B? - #8 by shayNV
We tried the suggestions in the topic, but couldn’t solve our problem.
log:
qichen@qichen-Nuvo-8208GC-Series:~/nvidia/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x$ sudo ./bootburn.sh -b e3550b03-t194b -u B_1_kernel B_1_kernel-dtb B_1_ramdisk -x /dev/ttyUSB7 -s --no_firmware_update
[sudo] password for qichen:
FlashCommandLineFromUser : -b e3550b03-t194b -u B_1_kernel B_1_kernel-dtb B_1_ramdisk -x /dev/ttyUSB7 -s --no_firmware_update
Using Python scripts
Bootburn Starting with arguments ['./bootburn.py', '-b', 'e3550b03-t194b', '-u', 'B_1_kernel', 'B_1_kernel-dtb', 'B_1_ramdisk', '-x', '/dev/ttyUSB7', '-s', '--no_firmware_update']
board is e3550b03-t194b
validating parameters
Check finished successfully
Done parsing command line
[bootburn]: [GetInfoRom(364)] : Read skuinfo from InfoRom...
[bootburn]: Execute command on Aurix serial port
[bootburn]: [GetTegrasAssocWithAurix(291)] : Setting Tegra-A on hold...
[bootburn]: [GetTegrasAssocWithAurix(293)] : Done
[bootburn]: [GetTegrasAssocWithAurix(296)] : Setting Tegra-B on hold...
[bootburn]: [GetTegrasAssocWithAurix(298)] : Done
[bootburn]: [executeShellCommand(154)] : shell command -- lsusb -d 0955: failed
[bootburn]: [executeShellCommand(156)] : {'cmd': ['lsusb', '-d', '0955:'], 'output': '', 'returncode': 1}
[bootburn]: [executeShellCommand(158)] :
[bootburn]: [executeShellCommand(161)] : 1
[bootburn]: [GetTegrasAssocWithAurix(314)] : Setting Tegra-B in recovery...
[bootburn]: [GetTegrasAssocWithAurix(318)] : Done
[bootburn]: [getListTargetsInRecovery(2847)] : Bus 001 Device 071: ID 0955:7019 NVidia Corp.
e3550b03-t194b
[bootburnTegra-B]: [setTargetConfigSkuInfo(429)] : s_skuargs :--skunum 940-63550-2000-100 --setprodinfo 940-63550-2000-100 AU --setskuversion F --setmacid mac0 0x00044BF66BE9
Bootburn Active
[bootburnTegra-B]: [getBoardFromBomDataTable(441)] : created list of lines from bom_data_table.txt file
target validation is successfully completed
[bootburnTegra-B]: [GetTargetECID(767)] : Target BR_CID: 0x88021911647df5011000000017fe8100
[bootburnTegra-B]: [GetTargetECID(768)] : Target ECID: 0x1647df5011000000017fe8100
[bootburnTegra-B]: [GenAdbSerialNum(469)] : ADB serial number is 2P3TUK0H000000BVT080
[bootburnTegra-B]: [CheckForDeviceType(831)] : Detected ES production device type
[bootburnTegra-B]: [SendAndBootAppletSigned(2000)] : Sending MB1 & Applet
[bootburnTegra-B]: [DisplayHostInfoAndPaths(302)] :
[bootburnTegra-B]: [DisplayHostInfoAndPaths(303)] : ############## Host machine info ##############
[bootburnTegra-B]: [DisplayHostInfoAndPaths(304)] : Host system Linux
[bootburnTegra-B]: [DisplayHostInfoAndPaths(305)] : Host node qichen-Nuvo-8208GC-Series
[bootburnTegra-B]: [DisplayHostInfoAndPaths(306)] : Host release 5.4.0-80-generic
[bootburnTegra-B]: [DisplayHostInfoAndPaths(307)] : Host version #90~18.04.1-Ubuntu SMP Tue Jul 13 19:40:02 UTC 2021
[bootburnTegra-B]: [DisplayHostInfoAndPaths(308)] : Host machine x86_64
[bootburnTegra-B]: [DisplayHostInfoAndPaths(309)] : Host processor x86_64
[bootburnTegra-B]: [DisplayHostInfoAndPaths(310)] : Target ChipId 0x19 ChipVersion 0x2
[bootburnTegra-B]: [DisplayHostInfoAndPaths(311)] : ###############################################
[bootburnTegra-B]: [DisplayHostInfoAndPaths(314)] :
[bootburnTegra-B]: [SendAndBootMB1Signed(1964)] : Sending MB1
[bootburnTegra-B]: [GenerateImage(2054)] : Generating Flashing-RCM Images
[bootburnTegra-B]: [BootRCMImage(2481)] : Sending Blob for RCM to target
[bootburnTegra-B]: [GenerateImage(2072)] : Generating Flash Images, this may take a few minutes
[bootburnTegra-B]: [GenerateImage(2088)] : Skipping file system flashing
[bootburnTegra-B]: [FlashImages(2403)] :
[bootburnTegra-B]: [FlashImages(2404)] : Flashing-Images starting
[bootburnTegra-B]: [CheckUSBServiceInit(205)] : Waiting for USB device. This may take up to 100 seconds...
[bootburnTegra-B]: [executeShellCommand(154)] : shell command -- lsusb -d 0955: failed
[bootburnTegra-B]: [executeShellCommand(156)] : {'cmd': ['lsusb', '-d', '0955:'], 'output': '', 'returncode': 1}
[bootburnTegra-B]: [executeShellCommand(158)] :
[bootburnTegra-B]: [executeShellCommand(161)] : 1
[bootburnTegra-B]: [CheckUSBServiceInit(221)] : Starting and finding the ADB device : 2P3TUK0H000000BVT080
[bootburnTegra-B]: [grepInFolder(238)] : /etc/udev/rules.d/70-snap.gnome-system-monitor.rules
[bootburnTegra-B]: [grepInFolder(241)] : []
[bootburnTegra-B]: [grepInFolder(238)] : /etc/udev/rules.d/70-snap.snapd.rules
[bootburnTegra-B]: [grepInFolder(238)] : /etc/udev/rules.d/70-snap.gnome-calculator.rules
[bootburnTegra-B]: [grepInFolder(238)] : /etc/udev/rules.d/70-snap.gnome-logs.rules
[bootburnTegra-B]: [grepInFolder(238)] : /etc/udev/rules.d/99-dvc-dev-event.rules
[bootburnTegra-B]: [grepInFolder(238)] : /etc/udev/rules.d/70-snap.gnome-characters.rules
[bootburnTegra-B]: [startADBServer(134)] : Starting ADB server
[bootburnTegra-B]: [FlashUsingADB(672)] : [3460000.sdhci] Flashing for Partition B_1_kernel-dtb
[bootburnTegra-B]: [FlashUsingADB(672)] : [3460000.sdhci] Flashing for Partition B_1_ramdisk
Skipping FW flashing
Resetting Aurix
[bootburn]: [AurixTegraReset(355)] : Re-setting x1
[bootburn]: [AurixTegraReset(358)] : Done
[bootburn]: [AurixTegraReset(355)] : Re-setting x2
Bootburn completed successfully!
Bootburn Time 30.7694461346 seconds
returning to directory /home/qichen/nvidia/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x_py
Cleaning up ...
Cleaning temp dir
