Hi there! In isaac-sim, the output directory is given to the writer and saved there. But is it possible to send the data as binary to a message queue using yield-stream, without writing it locally, and then save it elsewhere?
You certainly can. Build a custom writer to output the binary you need. Take a look at the docs here: Custom Writer — Omniverse Extensions
Thanks! I will try to write custom class with this feature, if I could not achieve this, I’ll ask it again
Related topics
| Data Format Conversion for Yolo-v8 Segmentation from Isaac Sim SDG | 1 | 276 | June 6, 2025 | |
| Write out non-render_products to a directory | 5 | 431 | April 13, 2023 | |
| Use of Omniverse Isaac in batch mode to produce pixel based output from an input USD file | 1 | 435 | June 15, 2022 | |
| Save camera position and rotation with Writer for offline dataset generation | 16 | 1604 | May 22, 2023 | |
| Output filenames - multiple render products for one writer, Isaac Sim | 0 | 88 | November 20, 2024 | |
| How to get the output file paths of Replicator BasicWriter? | 1 | 95 | October 10, 2025 | |
| Inference YOLO Pytorch model directly in Issac Sim or USD Composer | 0 | 73 | November 21, 2024 | |
| Cosmos Transfer from pictures? | 7 | 338 | March 4, 2026 | |
| How to write Raw USD Property each frame | 3 | 1171 | July 10, 2023 | |
| Capturing Specific Moment in Image Sequence with Isaac Sim Replicator | 3 | 554 | November 22, 2023 |
