Hello
I’m using the Replicator BasicWriter to output some artifacts per snippet below, following the examples from Writer Examples — Omniverse Extensions
with rep.new_layer():
# Add Default Light
distance_light = rep.create.light(rotation=(315,0,0), intensity=3000, light_type="distant")
camera = rep.create.camera(position=(0, 0, 1000))
render_product = rep.create.render_product(camera, (1024, 1024))
torus = rep.create.torus(semantics=[('class', 'torus')] , position=(0, -200 , 100))
sphere = rep.create.sphere(semantics=[('class', 'sphere')], position=(0, 100, 100))
cube = rep.create.cube(semantics=[('class', 'cube')], position=(100, -200 , 100) )
with rep.trigger.on_frame(num_frames=10):
with rep.create.group([torus, sphere, cube]):
rep.modify.pose(
position=rep.distribution.uniform((-100, -100, -100), (200, 200, 200)),
scale=rep.distribution.uniform(0.1, 2))
# Initialize and attach writer
writer = rep.WriterRegistry.get("BasicWriter")
writer.initialize( output_dir="_output", rgb=True, bounding_box_2d_tight=True)
writer.attach([render_product])
rep.orchestrator.run()
After the tasks have finished executing, Is there a way to query the exact file paths that are written out? I understand we can supply an output_dir but I’m interested in the individual output files.
Richard
