I am working with visualizing the output folder and I was a bit confused where can I get the rgb_path in the figure ?
rgb_path
is defined earlier in the examples:
out_dir = PATH_TO_REPLICATOR_OUTPUT_DIR
rgb = "rgb_0.png" # to be changed by you
rgb_path = os.path.join(out_dir, rgb_file_name)
rgb_image = Image.open(rgb_path)
Following this example PATH_TO_REPLICATOR_OUTPUT_DIR
is defined above in the code as:
output_dir="out_dir_test_visualization"
By default, non-absolute paths write files to ~/omni.replicator_out
. So for this example the files should be located in ~/omni.replicator_out/out_dir_test_visualization/
Thank you very much, Dennish.
I am trying to visualize coordinates of objects. Can you suggest some ways to visualize them.
