That did it - I’m able to boot into hybrid graphics mode now. However when I switch to intel (sudo prime-select intel), it kicks me out into TTY - I’m then able to do startx and make it work. However on next reboot I’m stuck in TTY again, and this time startx won’t work. I attached nvidia-bug-report.sh output in that condition. Also of interest is Xorg.0.log after the startx failure:
[ 158.715]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 158.715] X Protocol Version 11, Revision 0
[ 158.715] Build Operating System: Linux 4.4.0-119-generic x86_64 Ubuntu
[ 158.715] Current Operating System: Linux porty4 4.15.0-22-generic #24-Ubuntu SMP Wed May 16 12:15:17 UTC 2018 x86_64
[ 158.715] Kernel command line: BOOT_IMAGE=/vmlinuz-4.15.0-22-generic root=/dev/mapper/ubuntu--vg-root ro acpi_backlight=vendor
[ 158.715] Build Date: 13 April 2018 08:07:36PM
[ 158.715] xorg-server 2:1.19.6-1ubuntu4 (For technical support please see http://www.ubuntu.com/support)
[ 158.715] Current version of pixman: 0.34.0
[ 158.715] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 158.715] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 158.715] (==) Log file: "/home/arkamax/.local/share/xorg/Xorg.0.log", Time: Tue Jun 5 10:52:22 2018
[ 158.715] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 158.716] (==) No Layout section. Using the first Screen section.
[ 158.716] (==) No screen section available. Using defaults.
[ 158.716] (**) |-->Screen "Default Screen Section" (0)
[ 158.716] (**) | |-->Monitor "<default monitor>"
[ 158.716] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 158.716] (**) | |-->Device "Intel Graphics"
[ 158.716] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 158.716] (==) Automatically adding devices
[ 158.716] (==) Automatically enabling devices
[ 158.716] (==) Automatically adding GPU devices
[ 158.716] (==) Automatically binding GPU devices
[ 158.716] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 158.716] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 158.716] Entry deleted from font path.
[ 158.716] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 158.716] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 158.716] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 158.716] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 158.716] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 158.716] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 158.716] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 158.716] (II) Loader magic: 0x55c6f2313020
[ 158.716] (II) Module ABI versions:
[ 158.716] X.Org ANSI C Emulation: 0.4
[ 158.716] X.Org Video Driver: 23.0
[ 158.716] X.Org XInput driver : 24.1
[ 158.716] X.Org Server Extension : 10.0
[ 158.717] (++) using VT number 2
[ 158.718] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_33
[ 158.719] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 158.719] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 11 paused 0
[ 158.719] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 158.720] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 12 paused 0
[ 158.720] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/x86_64-linux-gnu/nvidia/xorg,/usr/lib/xorg/modules"
[ 158.720] (**) OutputClass "Nvidia Prime" ModulePath extended to "/x86_64-linux-gnu/nvidia/xorg,/usr/lib/x86_64-linux-gnu/nvidia/xorg,/usr/lib/xorg/modules"
[ 158.720] (**) OutputClass "Nvidia Prime" setting /dev/dri/card0 as PrimaryGPU
[ 158.721] (--) PCI: (0:0:2:0) 8086:191d:17aa:222e rev 6, Mem @ 0xd2000000/16777216, 0x60000000/536870912, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[ 158.721] (--) PCI:*(0:1:0:0) 10de:13b0:17aa:222e rev 162, Mem @ 0xd3000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/524288
[ 158.721] (II) LoadModule: "glx"
[ 158.721] (II) Loading /usr/lib/x86_64-linux-gnu/nvidia/xorg/libglx.so
[ 158.724] (II) Module glx: vendor="NVIDIA Corporation"
[ 158.724] compiled for 4.0.2, module version = 1.0.0
[ 158.724] Module class: X.Org Server Extension
[ 158.724] (II) NVIDIA GLX Module 390.48 Wed Mar 21 23:42:56 PDT 2018
[ 158.724] (II) LoadModule: "intel"
[ 158.724] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 158.724] (II) Module intel: vendor="X.Org Foundation"
[ 158.724] compiled for 1.19.5, module version = 2.99.917
[ 158.724] Module class: X.Org Video Driver
[ 158.724] ABI class: X.Org Video Driver, version 23.0
[ 158.724] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[ 158.725] (II) intel: Driver for Intel(R) HD Graphics
[ 158.725] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[ 158.725] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[ 158.725] xf86EnableIOPorts: failed to set IOPL for I/O (Operation not permitted)
[ 158.725] (II) intel(G0): Using Kernel Mode Setting driver: i915, version 1.6.0 20171023
[ 158.725] (II) intel(G0): SNA compiled: xserver-xorg-video-intel 2:2.99.917+git20171229-1 (Timo Aaltonen <tjaalton@debian.org>)
[ 158.725] (II) intel(G0): SNA compiled for use with valgrind
[ 158.745] (EE) No devices detected.
[ 158.745] (II) Applying OutputClass "nvidia" to /dev/dri/card0
[ 158.745] loading driver: nvidia
[ 158.745] (II) Applying OutputClass "Nvidia Prime" to /dev/dri/card0
[ 158.745] (==) Matched nvidia as autoconfigured driver 0
[ 158.745] (==) Matched nvidia as autoconfigured driver 1
[ 158.745] (==) Matched nouveau as autoconfigured driver 2
[ 158.745] (==) Matched nouveau as autoconfigured driver 3
[ 158.745] (==) Matched modesetting as autoconfigured driver 4
[ 158.745] (==) Matched fbdev as autoconfigured driver 5
[ 158.745] (==) Matched vesa as autoconfigured driver 6
[ 158.745] (==) Assigned the driver to the xf86ConfigLayout
[ 158.745] (II) LoadModule: "nvidia"
[ 158.745] (II) Loading /usr/lib/x86_64-linux-gnu/nvidia/xorg/nvidia_drv.so
[ 158.746] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 158.746] compiled for 4.0.2, module version = 1.0.0
[ 158.746] Module class: X.Org Video Driver
[ 158.746] (II) LoadModule: "nouveau"
[ 158.746] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 158.747] (II) Module nouveau: vendor="X.Org Foundation"
[ 158.747] compiled for 1.19.3, module version = 1.0.15
[ 158.747] Module class: X.Org Video Driver
[ 158.747] ABI class: X.Org Video Driver, version 23.0
[ 158.747] (II) LoadModule: "modesetting"
[ 158.747] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 158.747] (II) Module modesetting: vendor="X.Org Foundation"
[ 158.747] compiled for 1.19.6, module version = 1.19.6
[ 158.747] (II) LoadModule: "fbdev"
[ 158.747] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 158.748] (II) Module fbdev: vendor="X.Org Foundation"
[ 158.748] compiled for 1.19.3, module version = 0.4.4
[ 158.748] Module class: X.Org Video Driver
[ 158.748] ABI class: X.Org Video Driver, version 23.0
[ 158.748] (II) LoadModule: "vesa"
[ 158.748] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 158.748] (II) Module vesa: vendor="X.Org Foundation"
[ 158.748] compiled for 1.19.3, module version = 2.3.4
[ 158.748] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
[ 158.749] (II) intel: Driver for Intel(R) HD Graphics
[ 158.749] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[ 158.749] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[ 158.749] (II) NVIDIA dlloader X Driver 390.48 Wed Mar 21 23:18:15 PDT 2018
[ 158.749] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 158.749] (II) NOUVEAU driver Date: Fri Apr 21 14:41:17 2017 -0400
[ 158.749] (II) NOUVEAU driver for NVIDIA chipset families :
[ 158.749] RIVA TNT (NV04)
[ 158.749] RIVA TNT2 (NV05)
[ 158.749] GeForce 256 (NV10)
[ 158.749] GeForce 2 (NV11, NV15)
[ 158.749] GeForce 4MX (NV17, NV18)
[ 158.749] GeForce 3 (NV20)
[ 158.749] GeForce 4Ti (NV25, NV28)
[ 158.749] GeForce FX (NV3x)
[ 158.749] GeForce 6 (NV4x)
[ 158.749] GeForce 7 (G7x)
[ 158.749] GeForce 8 (G8x)
[ 158.749] GeForce GTX 200 (NVA0)
[ 158.749] GeForce GTX 400 (NVC0)
[ 158.749] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 158.749] (II) FBDEV: driver for framebuffer: fbdev
[ 158.749] (II) VESA: driver for VESA chipsets: vesa
[ 158.749] xf86EnableIOPorts: failed to set IOPL for I/O (Operation not permitted)
[ 158.750] (WW) Falling back to old probe method for modesetting
[ 158.750] (WW) Falling back to old probe method for fbdev
[ 158.750] (WW) Falling back to old probe method for vesa
[ 158.750] (II) systemd-logind: releasing fd for 226:0
[ 158.815] (EE) [drm] Failed to open DRM device for (null): -2
[ 158.839] (II) modeset(G1): using drv /dev/dri/card0
[ 158.839] (EE) No devices detected.
[ 158.839] (EE)
Fatal server error:
[ 158.839] (EE) no screens found(EE)
[ 158.839] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 158.839] (EE) Please also check the log file at "/home/arkamax/.local/share/xorg/Xorg.0.log" for additional information.
[ 158.839] (EE)
[ 158.854] (EE) Server terminated with error (1). Closing log file.
Looks like nouveau driver is loaded - but I’m fairly positive it was blacklisted:
$ cat /etc/modprobe.d/nvidia-graphics-drivers.conf
blacklist nouveau
blacklist lbm-nouveau
alias nouveau off
alias lbm-nouveau off
There are also a few entries of “xf86EnableIOPorts: failed to set IOPL for I/O (Operation not permitted)” - not sure what this refers to.
If I do sudo prime-select nvidia at that time, I can “startx”, but it’s stuck at login prompt loop. Rebooting brings things back to normal, but I’m not using Intel card at that point.
I’m almost there :|
nvidia-bug-report.log.gz (121 KB)
