I can’t login with new SDK Manager 1.2.0.
I was able to login with 1.1.0. (uninstall 1.2.0 and re-installed 1.1.0)
Another account caused same result.
Can you please provide the ~/.nvsdkm/sdkm.log file when log in fails with SDK Manager client 1.2.0?
14:46:49.791 - info: Logging in with sso login method…
14:46:49.860 - info: posting login request. url: https://devzone.auth0.com/oauth/token
14:47:19.877 - error: get token post request failed. Error: TimeoutError: Timeout awaiting ‘request’ for 30000ms
14:47:19.891 - info: posting login request. url: https://devzone.auth0.com/oauth/token
14:47:49.904 - error: get token post request failed. Error: TimeoutError: Timeout awaiting ‘request’ for 30000ms
14:47:49.920 - error: devzone signIn error, took 60.06s. Errors: developer db error: TimeoutError: Timeout awaiting ‘request’ for 30000ms. $
14:47:49.920 - error: loginManager.login failed: wrong_user_or_password
14:47:49.921 - info: Logging into Telemetry server: sso
Thanks xta-nakasendo.
We tested locally but couldn’t reproduce. Could it be a temporary network issue?
Thank you.
mmm… I can login via web browser or SDK manager 1.1.0 … but I can’t login via SDK manager 1.2.0…
Hi xta-nakasendo,
Are you using network proxy in SDK Manager?
Edward
Yes I am.
I was tried both of System configuration and Manual configuration.
Exactly the same problem. Can not login via sdkmanager 1.2 behind proxy. It was working for 1.1 version. Incorrect email or password error but can login to nvidia web page with same email and password.
We have released a new version, 1.2.0.6378, to fix this proxy issue. Please download it from NVIDIA SDK Manager | NVIDIA Developer and retry. Thank you.
I was able to login successfully via new version. Thank you very much.
SDK Manager 1.2.0.6738
the same problem
Error from site
Your account has been blocked after multiple consecutive login attempts. We’ve sent you an email with instructions on how to unblock it.
Hi s.kaminski,
If still can’ login now, please open a new topic for your issue. Thanks
Hi kayccc,
No changes. I opened a new topic for my issue.
