Login to SDK Manager
Dear Nvidia,
With my developer account, I cannot login to the Nvidia SDK Manager (even though I can login to the website). It would be much appreciated if you could assist as soon as possible.
Cheers
Hi @alexandra.tran,
I have forwarded this to our engineers for a look into your account.
Thanks for your patience.
Tom
Hi Alexandra. Can you please share what you are seeing? What specific error are you getting?
Fred
When I enter the username and password the following error appears: Incorrect email or password.
I am confident that the credentials are correct because I successfully login to this website.
I also tried with a different Nvidia account, but the same problem persists.
Can you please verify that in SDK Manager, you are logging in through ā€œNVIDIA DEVELOPERā€ tab and not ā€œNVONLINEā€ tab?
Yes absolutely, I’m definitely trying to login via the Nvidia Developer tab.
Hi Alexandra, can you package and upload the ~/.nvsdkm folder for further investigation?
In addition, are you behind a proxy server?
Yes corporate proxy server
Would you have any advice for dealing with the proxy server (eg accessing the program from terminal)? Would it be possible to download the SDK on a Windows PC and transfer it to the Linux for installation? Sorry I’m very new to this.
Hi Alexandra,
There is an issue when login via proxy, we are working on a fix for the issue. Will post you when the new build of SDK Manager client is ready.
Could you download the lastest sdkm build 1.2.0.6738 from NVIDIA SDK Manager | NVIDIA Developer, and check if it resolves your issue?
Thanks,
Changbin
Thank you for releasing a new sdk manager.
Unfortunately, I am receiving the message ā€˜Unable to connect. Check your internet / proxy settings’
It works now.
From command line, I circumvented the proxy ā€˜export http_proxy=’
Thanks for your help!
Glad to see the issue is now resolved:)
Hi NVIDIA,
Thank you for your assistance.
There still remains one issue.
When I attempt to flash the target hardware (Jetson TX2), the installation fails due to ā€˜VPI on Host: Failed to query debian packages details (host)’.
Is this an issue with the proxy server?
Hi @alexandra.tran,
Please start a new topic in the Jetson forum, as this section is not monitored by support staff.
Thanks,
Tom
