I will go with JetPack 4.1.1 Developer Preview until the solution will be found.
Any suggestions around “UNABLE_TO_GET_ISSUER_CERT_LOCALLY” is welcome.
For someone who is kind enough, I will put the current status.
Host: Ubuntu 18.04.2 LTS
Device: Xavier
Network: Host and Xavier have been inside proxy.
Devzone account: activated.
SDK Manager: 0.9.11.3405
SDK Manager proxy settings: done
Connection from the SDK Manager@host to the devzone: should be OK except certification issue.
SDK Manager log is shown below.
Note: I have finished the installation on Xavier with JetPack 4.1.1 Developer Preview.
Network related tools of apt and others worked with current conditions.
Thank you so much for new SDK manager. It has worked under my environment.
The answer of the following question is that “I have not installed the root certificate.” However, I “GUESS” the proxy server which I do not manage might do that.
Do you have root certificate installed on your host machine, such as installed it to /etc/ssl/certs with update-ca-certificates?
By the way, new SDK Manager has a good improvement that it can get the prosxy settings from the system. Things have been getting better and better.
I have the same problem with shinos9q35. I also have been trying to install the JetPack 4.2 on the Xavier via the SDK Manager. I can log in it through browsers, but not by sdkmanager.
I can not log into nvidia.developer.com using SDK Manager Beta given in the following website.
As you guided, I installed root certificate in /etc/ssl/certs with update-ca-certificates by following the following link but ended up with no success.
Of course. I do not exactly know how to achieve proxy server setting in Ubuntu, but the proxy server setting which I get by typing wget http://google.com is as follows.
Hi Sunghun,
According to ~/.nvsdkm/sdkm.log, your tried several times to sign in with your NVIDIA developer account.
At first it seems that you entered the wrong username/password, and finally it causes your account is blocked.
Please go to your inbox of the email account and follow the instruction to unblock it.
