I has customer report that AGX Xavier DVK cannot find two different vendor's M.2 key m SSD on internal m.2 slot[J1] but can found on a PCIe slot [J6] with adapter.
I has customer report that AGX Xavier DVK cannot find two different vendor’s M.2 key m SSD on internal m.2 slot[J1] but can found on a PCIe slot [J6] with adapter.
vendor 1: M.2m SSD Adata SX8000 .
vendor 2: M.2m SSD Kingston KC1000 (PCIe SSD )].
we has tried PC SN520 M.2 NVME SSD on customer Xavier DVK internal m.2 slot[J1] and can found under Ubuntu.
Hi abraham85,
Could you share the kernel log? We do not have comprehensive test for all kinds of SSD.
This thread has pointed out what ssd we support.
https://devtalk.nvidia.com/default/topic/1039025/jetson-agx-xavier/m-2-nvme-compatibility/2
It was the issue I have actually.
I know Xavier DVK’s m.2 socket only supports NVMe SSD. I am 100% sure that both Adata SX8000 and Kingston KC1000 are m.2 NVMe SSD and they work fine on many PC mother boards with chipset such as intel H310, B360, Z390 either internal m.2 NVMe socket or via a passive PCIe-to-nvme adapter on the PCIe slot, you can refer to M.2 NVMe SSD PCIe to PCIe 3.0 X4 Adapter + M.2 NVMe Cooling Heatsink - Support PCI-E NVME 2280, 2260, 2242,2230 for Samsung950Pro, 960Evo, XP940, PM951, PM961, SM951, SM961, OCA RD400, Toshiba BG1 ect - Newegg.com for such adapter.
The strange thing is the SSDs don’t work on Xavier DVK’s internal m.2 NVMe socket but they work fine if installed via the passive PCIe-to-NVMe adapter on the DVK’s PCIe slot, so I assume the Xavier software should be fine.
So the question should be “What are differences between the internal NVMe socket and PCIe slot?”
Thanks,
TK
Hi tien-kuen,
I think it is still better if you could share the kernel log.
Hello Wayne,
Please see attached kern.log with Adata SX8000NP 128GB NVME SSD plugged on J1 M.2 slot.
Sorry I don’t know how to attached it as a file.
Thanks,
Tien-Kuen
Jun 21 14:29:02 nvidia-xavier kernel: [ 400.169491] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Jun 21 14:29:02 nvidia-xavier kernel: [ 400.169562] Bluetooth: BNEP socket layer initialized
Jun 21 14:31:28 nvidia-xavier kernel: [ 545.867154] tegradc 15200000.nvdisplay: blank - powerdown
Jun 21 14:31:28 nvidia-xavier kernel: [ 545.926630] extcon-disp-state external-connection:disp-state: cable 48 state 0 already set.
Jun 21 14:31:28 nvidia-xavier kernel: [ 545.926633] Extcon AUX2(HDMI) disable
Jun 21 14:31:28 nvidia-xavier kernel: [ 545.956186] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
Jun 21 14:31:28 nvidia-xavier kernel: [ 545.965325] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
Jun 21 14:31:28 nvidia-xavier kernel: [ 545.965560] tegradc 15210000.nvdisplay: blank - powerdown
Jun 21 14:31:28 nvidia-xavier kernel: [ 545.965566] tegradc 15220000.nvdisplay: blank - powerdown
Jun 21 14:31:31 nvidia-xavier kernel: [ 545.973981] tegradc 15200000.nvdisplay: blank - powerdown
Jun 21 14:31:31 nvidia-xavier kernel: [ 545.974008] tegradc 15200000.nvdisplay: unblank
Jun 21 14:31:31 nvidia-xavier kernel: [ 545.974663] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
Jun 21 14:31:31 nvidia-xavier kernel: [ 545.974760] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
Jun 21 14:31:31 nvidia-xavier kernel: [ 545.976393] Parent Clock set for DC plld3
Jun 21 14:31:31 nvidia-xavier kernel: [ 545.980312] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
Jun 21 14:31:31 nvidia-xavier kernel: [ 549.417492] tegradc 15200000.nvdisplay: blank - powerdown
Jun 21 14:31:31 nvidia-xavier kernel: [ 549.481771] extcon-disp-state external-connection:disp-state: cable 48 state 0 already set.
Jun 21 14:31:31 nvidia-xavier kernel: [ 549.481780] Extcon AUX2(HDMI) disable
Jun 21 14:31:31 nvidia-xavier kernel: [ 549.503810] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
Jun 21 14:31:31 nvidia-xavier kernel: [ 549.504271] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
Jun 21 14:31:31 nvidia-xavier kernel: [ 549.504499] tegradc 15200000.nvdisplay: unblank
Jun 21 14:31:31 nvidia-xavier kernel: [ 549.505318] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
Jun 21 14:31:31 nvidia-xavier kernel: [ 549.505462] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
Jun 21 14:31:31 nvidia-xavier kernel: [ 549.507053] Parent Clock set for DC plld3
Jun 21 14:31:31 nvidia-xavier kernel: [ 549.512170] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
Jun 21 14:31:31 nvidia-xavier kernel: [ 549.516910] tegradc 15200000.nvdisplay: unblank
Jun 21 14:31:31 nvidia-xavier kernel: [ 549.516940] tegradc 15210000.nvdisplay: blank - powerdown
Jun 21 14:31:31 nvidia-xavier kernel: [ 549.516946] tegradc 15220000.nvdisplay: blank - powerdown
Jun 21 14:31:42 nvidia-xavier kernel: [ 560.690897] tegradc 15200000.nvdisplay: blank - powerdown
Jun 21 14:31:42 nvidia-xavier kernel: [ 560.747087] extcon-disp-state external-connection:disp-state: cable 48 state 0 already set.
Jun 21 14:31:42 nvidia-xavier kernel: [ 560.747089] Extcon AUX2(HDMI) disable
Jun 21 14:31:42 nvidia-xavier kernel: [ 560.769411] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
Jun 21 14:31:42 nvidia-xavier kernel: [ 560.769966] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
Jun 21 14:31:42 nvidia-xavier kernel: [ 560.770160] tegradc 15210000.nvdisplay: blank - powerdown
Jun 21 14:31:42 nvidia-xavier kernel: [ 560.770166] tegradc 15220000.nvdisplay: blank - powerdown
Jun 21 14:31:42 nvidia-xavier kernel: [ 560.876881] tegradc 15200000.nvdisplay: blank - powerdown
Jun 21 14:31:42 nvidia-xavier kernel: [ 560.876901] tegradc 15200000.nvdisplay: unblank
Jun 21 14:31:42 nvidia-xavier kernel: [ 560.877739] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
Jun 21 14:31:42 nvidia-xavier kernel: [ 560.877838] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
Jun 21 14:31:43 nvidia-xavier kernel: [ 560.879926] Parent Clock set for DC plld3
Jun 21 14:31:43 nvidia-xavier kernel: [ 560.884678] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
Jun 21 14:31:43 nvidia-xavier kernel: [ 560.889297] tegradc 15200000.nvdisplay: unblank
Jun 21 14:31:43 nvidia-xavier kernel: [ 560.889332] tegradc 15210000.nvdisplay: blank - powerdown
Jun 21 14:31:43 nvidia-xavier kernel: [ 560.889338] tegradc 15220000.nvdisplay: blank - powerdown
Jun 21 14:38:37 nvidia-xavier kernel: [ 975.080009] systemd: 33 output lines suppressed due to ratelimiting
Jun 21 14:39:59 nvidia-xavier kernel: [ 1057.081178] Bridge firewalling registered
Jun 21 14:39:59 nvidia-xavier kernel: [ 1057.096394] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
Jun 21 14:39:59 nvidia-xavier kernel: [ 1057.389150] Netfilter messages via NETLINK v0.30.
Jun 21 14:39:59 nvidia-xavier kernel: [ 1057.391043] ctnetlink v0.93: registering with nfnetlink.
Jun 21 14:39:59 nvidia-xavier kernel: [ 1057.509385] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-2988) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Wed Mar 13 00:30:11 PDT 2019
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] OF: fdt:memory scan node memory, reg size 48,
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] OF: fdt: - 80000000 , 2b000000
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] OF: fdt: - ab200000 , 3da00000
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] OF: fdt: - 100000000 , 380000000
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] bootconsole [tegra_comb_uart0] enabled
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] Found tegra_fbmem: 00140000@a0697000
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] Found lut_mem: 00002008@a0692000
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] Found vpr, start=0xf0000000 size=8000000
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb3_carveout’: base 0x0000000000000000, size 0 MiB
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] cma: Reserved 64 MiB at 0x00000000e4800000
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] On node 0 totalpages: 4097725
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] DMA zone: 6683 pages used for memmap
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] DMA zone: 0 pages reserved
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] DMA zone: 427709 pages, LIFO batch:31
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] Normal zone: 57344 pages used for memmap
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] Normal zone: 3670016 pages, LIFO batch:31
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] psci: probing for conduit method from DT.
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] psci: PSCIv1.0 detected in firmware.
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] psci: Using standard PSCI v0.2 function IDs
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] psci: SMC Calling Convention v1.1
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc3ffda6000 s53400 r8192 d32616 u94208
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] pcpu-alloc: s53400 r8192 d32616 u94208 alloc=23*4096
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] Speculative Store Bypass Disable mitigation not required
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 4033698
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x140000@0xa0697000 lut_mem=0x2008@0xa0692000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.2.2 vpr=0x8000000@0xf0000000 sdhci_tegra.en_boot_part_access=1
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] log_buf_len total cpu_extra contributions: 229376 bytes
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] log_buf_len min size: 32768 bytes
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] log_buf_len: 262144 bytes
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] early log buf free: 29232(89%)
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] Memory: 16001716K/16390900K available (15166K kernel code, 2914K rwdata, 6616K rodata, 8512K init, 605K bss, 323648K reserved, 65536K cma-reserved)
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] Virtual kernel memory layout:
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f50000 ( 15168 KB)
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] .rodata : 0xffffff8008f50000 - 0xffffff80095d0000 ( 6656 KB)
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] .init : 0xffffff80095d0000 - 0xffffff8009e20000 ( 8512 KB)
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] .data : 0xffffff8009e20000 - 0xffffff800a0f8808 ( 2915 KB)
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] .bss : 0xffffff800a0f8808 - 0xffffff800a18fe3c ( 606 KB)
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] 0xffffffbf00000000 - 0xffffffbf10000000 ( 256 MB actual)
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] memory : 0xffffffc000000000 - 0xffffffc400000000 ( 16384 MB)
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] Preemptible hierarchical RCU implementation.
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] Build-time adjustment of leaf fanout to 64.
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] NR_IRQS:64 nr_irqs:64 0
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] GIC: Using split EOI/Deactivate mode
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.000010] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.009638] Console: colour dummy device 80x25
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.012427] console [tty0] enabled
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.015882] bootconsole [tegra_comb_uart0] disabled
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.020889] kmemleak: Kernel memory leak detector disabled
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.020961] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.021024] pid_max: default: 32768 minimum: 301
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.022438] Security Framework initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.023173] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.023212] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.025763] ftrace: allocating 46802 entries in 183 pages
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.495320] sched-energy: Sched-energy-costs installed from DT
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.495503] ASID allocator initialised with 65536 entries
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.536587] tegra-id: chipid=21917.
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.536626] tegra-id: opt_subrevision=0.
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.536718] Tegra Revision: A02 SKU: 0xd0 CPU Process: 0 SoC Process: 0
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.536794] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.537005] DTB Build time: Mar 13 2019 00:34:33
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.588319] CPU1: Booted secondary processor [4e0f0040]
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.620411] CPU2: Booted secondary processor [4e0f0040]
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.652716] CPU3: Booted secondary processor [4e0f0040]
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.685368] CPU4: Booted secondary processor [4e0f0040]
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.717536] CPU5: Booted secondary processor [4e0f0040]
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.749847] CPU6: Booted secondary processor [4e0f0040]
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.781713] CPU7: Booted secondary processor [4e0f0040]
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.782621] Brought up 8 CPUs
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.783520] SMP: Total of 8 processors activated.
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.783619] CPU features: detected feature: Privileged Access Never
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.783680] CPU features: detected feature: LSE atomic instructions
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.783743] CPU features: detected feature: User Access Override
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.783804] CPU features: detected feature: 32-bit EL0 Support
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.789839] CPU: All CPU(s) started at EL2
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.790048] alternatives: patching kernel code
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.805216] devtmpfs: initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.892788] Initilizing CustomIPI irq domain
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.893408] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.893544] futex hash table entries: 2048 (order: 5, 131072 bytes)
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.895662] pinctrl core: initialized pinctrl subsystem
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.895973] OS set in device tree is not L4T.
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.896351] regulator-dummy: no parameters
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.896686] Initializing plugin-manager
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.896782] Plugin module not found
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.896853] Plugin-manager status disabled
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.898777] NET: Registered protocol family 16
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.907662] pstore: using zlib compression
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.909236] console [pstore-1] enabled
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.909308] pstore: Registered ramoops as persistent store backend
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.909402] ramoops: attached 0x200000@0xe8a00000, ecc: 0/0
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.927596] cpuidle: using governor menu
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.929574] bpmp: waiting for handshake
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.929633] bpmp: handshake completed
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.929698] bpmp: synchronizing channels
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.929748] bpmp: channels synchronized
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.929797] bpmp: mail init ok
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.934276] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.934648] t19x-arm-smmu 12000000.iommu: probing hardware configuration…
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.934755] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.934812] t19x-arm-smmu 12000000.iommu: stage 1 translation
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.934871] t19x-arm-smmu 12000000.iommu: stage 2 translation
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.934930] t19x-arm-smmu 12000000.iommu: nested translation
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.934991] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.935075] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.935170] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.935238] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.935337] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.940818] vdso: 2 pages (1 code @ ffffff8008f57000, 1 data @ ffffff8009e24000)
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.941537] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.946267] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.947853] Registering BPMP clocks…
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.948096] tegra_bpmp_clk_init: clock init ok (395 clks)
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.948680] tegra_bpmp_of_clk_init: EMC proxy not found.
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.949453] tegra_powergate_init: DONE
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.949684] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.949895] DTB Build time: Mar 13 2019 00:34:33
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.954456] Tegra reboot handler registered.
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.965176] iommu: Adding device 14180000.pcie to group 0
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.966135] iommu: Adding device 14100000.pcie to group 1
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.967122] iommu: Adding device 14140000.pcie to group 2
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.968220] iommu: Adding device 141a0000.pcie to group 3
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.970462] iommu: Adding device 2490000.ether_qos to group 4
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.971303] iommu: Adding device 3100000.serial to group 5
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.972172] iommu: Adding device 3110000.serial to group 6
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.972816] iommu: Adding device 3140000.serial to group 7
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.973730] tegra-pmc c360000.pmc: scratch reg offset dts data not present
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.974058] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.974161] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.974226] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.974287] tegra-pmc: ### PMC reset status reg: 0x2d
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.974407] tegra-pmc: PMC Prod config success
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.974749] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.974853] tegra-pmc c360000.pmc: IO padctrl driver initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.975442] iommu: Adding device 3460000.sdhci to group 8
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.976327] iommu: Adding device 3400000.sdhci to group 9
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.977292] iommu: Adding device 2450000.ufshci to group 10
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.978148] iommu: Adding device c260000.spi to group 11
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.979350] iommu: Adding device 3160000.i2c to group 12
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.979984] iommu: Adding device c240000.i2c to group 13
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.980680] iommu: Adding device 3180000.i2c to group 14
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.981300] iommu: Adding device 3190000.i2c to group 15
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.982204] iommu: Adding device 31b0000.i2c to group 16
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.983092] iommu: Adding device 31c0000.i2c to group 17
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.983735] iommu: Adding device c250000.i2c to group 18
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.984573] iommu: Adding device 31e0000.i2c to group 19
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.985858] iommu: Adding device sound to group 20
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.986688] iommu: Adding device 3510000.hda to group 21
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.987560] iommu: Adding device bc00000.rtcpu to group 22
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.991204] iommu: Adding device 13e10000.host1x to group 23
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.991801] iommu: Adding device 13e10000.host1x:ctx0 to group 24
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.992476] iommu: Adding device 13e10000.host1x:ctx1 to group 25
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.993330] iommu: Adding device 13e10000.host1x:ctx2 to group 26
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.993929] iommu: Adding device 13e10000.host1x:ctx3 to group 27
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.994558] iommu: Adding device 13e10000.host1x:ctx4 to group 28
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.995152] iommu: Adding device 13e10000.host1x:ctx5 to group 29
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.995744] iommu: Adding device 13e10000.host1x:ctx6 to group 30
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.996592] iommu: Adding device 13e10000.host1x:ctx7 to group 31
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.997513] iommu: Adding device 15340000.vic to group 32
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.998190] iommu: Adding device 15380000.nvjpg to group 33
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.998856] iommu: Adding device 15500000.tsec to group 34
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.999316] iommu: Adding device 15100000.tsecb to group 35
Jun 21 14:41:47 nvidia-xavier kernel: [ 0.999762] iommu: Adding device 15480000.nvdec to group 36
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.000229] iommu: Adding device 15140000.nvdec1 to group 37
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.000739] iommu: Adding device 154c0000.nvenc to group 38
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.001191] iommu: Adding device 15a80000.nvenc1 to group 39
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.001875] iommu: Adding device 15880000.nvdla0 to group 40
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.002529] iommu: Adding device 158c0000.nvdla1 to group 41
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.003414] iommu: Adding device 15200000.nvdisplay to group 42
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.003790] platform 15200000.nvdisplay: IOVA linear map 0x00000000a0697000(140000)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.003871] platform 15200000.nvdisplay: IOVA linear map 0x00000000a0692000(3000)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.005201] platform 15200000.nvdisplay: IOVA linear map 0x00000000f0000000(8000000)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.005268] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.006054] iommu: Adding device 15210000.nvdisplay to group 43
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.006159] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.006835] iommu: Adding device 15220000.nvdisplay to group 44
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.006942] t19x-arm-smmu: Adding 15220000.nvdisplay to ISO SMMU client
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.009974] iommu: Adding device 15c10000.vi to group 45
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.010265] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.010853] iommu: Adding device 14800000.isp to group 46
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.012879] iommu: Adding device 16000000.pva0 to group 47
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.013769] iommu: Adding device 16800000.pva1 to group 48
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.014422] iommu: Adding device 15810000.se to group 49
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.015059] iommu: Adding device 15820000.se to group 50
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.015567] iommu: Adding device 15830000.se to group 51
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.016036] iommu: Adding device 15840000.se to group 52
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.016601] iommu: Adding device c1a0000.aon to group 53
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.018860] iommu: Adding device d000000.bpmp to group 54
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.019386] bpmp: ping status is 0
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.019636] bpmp d000000.bpmp: firmware tag is 1c1b2165fe52a0a54ad7caf60d40cdc3
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.024298] bpmp d000000.bpmp: probe ok
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.026645] tegra-reset 0.bpmp_reset: registered 186 resets.
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.027375] iommu: Adding device smmu_test to group 55
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.029028] mc: mapped MMIO address: 0xffffff800a560000 → 0x2c10000
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.029120] mc: mapped MMIO address: 0xffffff800a580000 → 0x2c20000
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.029204] mc: mapped MMIO address: 0xffffff800a5a0000 → 0x2c30000
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.029288] mc: mapped MMIO address: 0xffffff800a5c0000 → 0x2c40000
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.029401] mc: mapped MMIO address: 0xffffff800a5e0000 → 0x2c50000
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.029485] mc: mapped MMIO address: 0xffffff800a7b0000 → 0x2b80000
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.029589] mc: mapped MMIO address: 0xffffff800a7d0000 → 0x2b90000
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.029709] mc: mapped MMIO address: 0xffffff800b010000 → 0x2ba0000
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.029792] mc: mapped MMIO address: 0xffffff800b030000 → 0x2bb0000
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.029869] mc: mapped MMIO address: 0xffffff800b050000 → 0x1700000
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.029946] mc: mapped MMIO address: 0xffffff800b070000 → 0x1710000
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.030021] mc: mapped MMIO address: 0xffffff800b090000 → 0x1720000
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.030101] mc: mapped MMIO address: 0xffffff800b0b0000 → 0x1730000
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.030176] mc: mapped MMIO address: 0xffffff800b0d0000 → 0x1740000
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.030250] mc: mapped MMIO address: 0xffffff800b0f0000 → 0x1750000
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.030324] mc: mapped MMIO address: 0xffffff800b110000 → 0x1760000
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.030401] mc: mapped MMIO address: 0xffffff800b130000 → 0x1770000
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.030552] mc-err: mcerr ops are set to t19x
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.039680] iommu: Adding device 2600000.dma to group 56
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.047969] GPIO line 490 (pcie-reg-enable) hogged as output/high
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.048065] GPIO line 289 (pcie-reg-enable) hogged as output/high
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.048155] GPIO line 339 (wifi-enable) hogged as output/high
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.048844] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.059046] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.059614] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.062821] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.062876] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.064132] iommu: Adding device 3550000.xudc to group 57
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.065293] iommu: Adding device 3610000.xhci to group 58
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.068889] arm64_ras arm64_ras: probed
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.069485] ras_fhi_enable: FHI 477 enabled on CPU0
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.069607] ras_fhi_enable: FHI 478 enabled on CPU1
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.069764] ras_fhi_enable: FHI 479 enabled on CPU2
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.069912] ras_fhi_enable: FHI 480 enabled on CPU3
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.070035] ras_fhi_enable: FHI 481 enabled on CPU4
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.070184] ras_fhi_enable: FHI 482 enabled on CPU5
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.070295] ras_fhi_enable: FHI 483 enabled on CPU6
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.070412] ras_fhi_enable: FHI 484 enabled on CPU7
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.070885] carmel_ras_enable: RAS enabled on cpu0
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.071216] carmel_ras_enable: RAS enabled on cpu1
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.071572] carmel_ras_enable: RAS enabled on cpu2
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.071872] carmel_ras_enable: RAS enabled on cpu3
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.072195] carmel_ras_enable: RAS enabled on cpu4
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.072493] carmel_ras_enable: RAS enabled on cpu5
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.072781] carmel_ras_enable: RAS enabled on cpu6
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.073058] carmel_ras_enable: RAS enabled on cpu7
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.073175] carmel_ras carmel_ras: probed
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.075043] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 486, noc_nonsecure_irq = 485>
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.075829] tegra-cbb c600000.aon-noc: noc_secure_irq = 488, noc_nonsecure_irq = 487>
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.077060] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 490, noc_nonsecure_irq = 489>
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.078298] tegra-cbb be00000.rce-noc: noc_secure_irq = 492, noc_nonsecure_irq = 491>
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.079498] tegra-cbb b600000.sce-noc: noc_secure_irq = 494, noc_nonsecure_irq = 493>
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.080131] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.083815] vdd-3v3-cvb: 3300 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.084281] vdd-1v8-cvb: 1800 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.084827] vdd-1v8-sd: 1800 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.085420] vdd-epb-1v0: supplied by vdd-3v3-cvb
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.085512] vdd-epb-1v0: 1000 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.086008] vdd-sdmmc1-sw: 3300 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.086600] avdd-cam-2v8: 2800 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.087036] vdd-sata-1v5: 1500 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.087444] vdd-1v8-slt: 1800 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.087906] vdd-3v3-slt: 3300 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.088334] vdd-fan: 5000 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.088874] vdd-hdmi-5v0: 5000 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.089364] vdd_sys_en: 1200 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.090063] vdd-5v-sata: 5000 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.090643] vdd-ac-bat: 5000 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.090932] vdd-5v-sata: supplied by vdd-ac-bat
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.123923] HugeTLB registered 2 MB page size, pre-allocated 0 pages
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.129461] eventlib_kernel: keventlib is initialized, test id: 0
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.129921] SCSI subsystem initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.130498] libata version 3.00 loaded.
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.130864] usbcore: registered new interface driver usbfs
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.130986] usbcore: registered new interface driver hub
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.131149] usbcore: registered new device driver usb
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.145353] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.149245] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.155208] vdd-1v0: at 1000 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.159241] vdd-1v8-hs: at 1800 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.163306] vdd-1v8-ls: at 1800 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.167452] vdd-1v8-ao: at 1800 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.171401] vddio-ddr-1v1: at 1100 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.175144] vdd-rtc: at 800 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.176287] spmic-ldo1: at 2375 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.183219] vdd-ao-3v3: at 3300 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.191283] vddio-emmc-3v3: at 3300 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.192633] spmic-ldo4: at 1587 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.199283] vdd-usb-3v3: at 3300 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.206991] vddio-sdmmc1-3v3: at 3300 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.210996] vdd-csi-1v2: at 1200 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.212404] spmic-ldo8: at 1800 mV
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.213969] GPIO line 246 (gpio_default) hogged as output/high
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.214944] GPIO line 247 (gpio_default) hogged as output/high
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.215600] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.219538] max77620 4-003c: max77620 probe successful
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.220388] media: Linux media interface: v0.10
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.220493] Linux video capture interface: v2.00
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.222227] pps_core: LinuxPPS API ver. 1 registered
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.222274] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.222374] PTP clock support registered
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.223324] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.223446] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.225114] tegra_fiq_debugger_init: found FIQ source (IRQ 469)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.227209] Advanced Linux Sound Architecture Driver Initialized.
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.227988] Bluetooth: Core ver 2.22
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.228071] NET: Registered protocol family 31
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.228113] Bluetooth: HCI device and connection manager initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.228180] Bluetooth: HCI socket layer initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.228238] Bluetooth: L2CAP socket layer initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.228304] Bluetooth: SCO socket layer initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.231655] camchar: rtcpu character device driver loaded
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.233366] clocksource: Switched to clocksource arch_sys_counter
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.292293] VFS: Disk quotas dquot_6.6.0
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.292505] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.293106] nvmap_heap_init: nvmap_heap_init: created heap block cache
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.295220] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.295402] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000f0000000,134217728
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.295476] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.295544] nvmap_page_pool_init: Total RAM pages: 4016813
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.295588] nvmap_page_pool_init: nvmap page pool size: 502101 pages (1961 MB)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.295983] nvmap_background_zero_thread: PP zeroing thread starting.
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.296495] misc nvmap: created heap vpr base 0x00000000f0000000 size (131072KiB)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.298917] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.316518] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.316940] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.317329] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.317727] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.318363] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.318745] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.318963] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.320490] la/ptsa driver initialized.
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.320977] NET: Registered protocol family 2
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.322254] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.323029] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.323859] TCP: Hash tables configured (established 131072 bind 65536)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.323973] UDP hash table entries: 8192 (order: 6, 262144 bytes)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.324311] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.325025] NET: Registered protocol family 1
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.326066] RPC: Registered named UNIX socket transport module.
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.326119] RPC: Registered udp transport module.
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.326159] RPC: Registered tcp transport module.
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.326199] RPC: Registered tcp NFSv4.1 backchannel transport module.
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.326279] PCI: CLS 0 bytes, default 64
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.326575] Trying to unpack rootfs image as initramfs…
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.357710] host1x 13e10000.host1x: initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.361093] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.368593] audit: initializing netlink subsys (disabled)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.368705] audit: type=2000 audit(0.908:1): initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.370016] workingset: timestamp_bits=46 max_order=22 bucket_order=0
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.384801] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.386712] ntfs: driver 2.1.32 [Flags: R/W].
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.387666] 9p: Installing v9fs 9p2000 file system support
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.394131] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.398674] io scheduler noop registered
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.399042] io scheduler cfq registered (default)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.403728] gic 2a41000.agic-controller: GIC IRQ controller registered
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.405161] random: fast init done
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.409861] iommu: Adding device 2993000.adsp to group 59
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.421785] iommu: Adding device aconnect@2a41000:adsp_audio to group 60
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.422050] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.439447] tegra-pwm c340000.pwm: PWM clk can sleep in ops
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.440164] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.440826] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.444739] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.445066] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.445122] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=2000000, max_bw=4687500
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.449634] tsec 15500000.tsec: initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.452719] tsec 15100000.tsecb: initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.459080] nvdec 15480000.nvdec: initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.463163] nvdec 15140000.nvdec1: initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.470447] falcon 15340000.vic: initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.473014] falcon 15380000.nvjpg: initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.476061] falcon 154c0000.nvenc: initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.478856] falcon 15a80000.nvenc1: initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.483730] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.487733] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.491889] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.495660] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.498056] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.500495] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.502861] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.505255] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.510595] t194-nvcsi 15a00000.nvcsi: initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.517408] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.518093] scare-pigeon 14b00000.isp-thi: initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.529226] pva 16000000.pva0: initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.562230] pva 16800000.pva1: initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.593921] nvdla 15880000.nvdla0: initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.625016] nvdla 158c0000.nvdla1: initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.629600] tegra-slvs-ec 15ac0000.slvs-ec: initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.629839] tegra-slvs-ec 15ac0000.slvs-ec: no streams defined
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.629884] tegra-slvs-ec 15ac0000.slvs-ec: failed to init SLVS media controller (-19)
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.629930] tegra-slvs-ec 15ac0000.slvs-ec: probed
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.631369] tegradccommon 15200000.dc_common: host1x channel mapped
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.631439] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.631585] tegradccommon 15200000.dc_common: dma mapping done
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.632976] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor2
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.633132] generic_infoframe_type: 0x87
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.633319] tegradc 15200000.nvdisplay: DT parsed successfully
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.633451] tegradc 15200000.nvdisplay: Display dc.ffffff800bd90000 registered with id=0
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.639343] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.639441] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.639488] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.639944] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.639993] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.642122] tegradc 15200000.nvdisplay: Bootloader disp_param detected. Detected mode: 640x480 (on 0x0mm) pclk=50347983
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.645148] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.645201] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.648821] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.649916] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.650428] kfuse 3830000.kfuse: initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.650960] tegradc 15200000.nvdisplay: probed
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.659594] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.663685] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 50, base_baud = 0) is a TEGRA_UART
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.665604] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 51, base_baud = 0) is a TEGRA_UART
Jun 21 14:41:47 nvidia-xavier kernel: [ 1.666911] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 52, base_baud = 0) is a TEGRA_UART
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.149151] console [ttyTCU0] enabled
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.149716] Console: switching to colour frame buffer device 80x30
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.149978] [drm] Initialized
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.161957] tegradc 15200000.nvdisplay: fb registered
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.167474] gpio tegra-gpio wake71 for gpio=98(M:2)
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.172986] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.178165] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.186460] brd: module loaded
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.196852] loop: module loaded
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.197151] tegra_profiler: version: 1.132, samples/io: 46/26
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.197564] tegra_profiler: auth: init
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.198694] Parent Clock set for DC plld3
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.204461] nct1008_nct72 4-004c: starting parse dt
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.205062] THERMAL EST: found 3 subdevs
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.205068] THERMAL EST num_resources: 0
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.205074] [THERMAL EST subdev 0]
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.205079] [THERMAL EST subdev 1]
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.205084] [THERMAL EST subdev 2]
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.205632] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.205636] THERMAL EST: thz register success.
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.205854] THERMAL EST: end of probe, return err: 0
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.206935] ufs_tegra 2450000.ufshci: freq-table-hz property not specified
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.206945] ufs_tegra 2450000.ufshci: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.207942] ufs_tegra 2450000.ufshci: wakeup init done, cdirq 459
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.207951] gpio tegra-gpio-aon wake25 for gpio=32(EE:0)
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.220736] scsi host0: ufshcd
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.234208] hisi_sas: driver version v1.6
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.251030] tegradc 15200000.nvdisplay: hdmi: tmds rate:50349K prod-setting:prod_c_hdmi_0m_54m
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.251945] tegradc 15200000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.251959] tegradc 15200000.nvdisplay: hdmi: BL set VIC 0
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.251963] tegradc 15200000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.252699] extcon-disp-state external-connection:disp-state: cable 48 state 1
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.252702] Extcon AUX2(HDMI) enable
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.253094] libphy: Fixed MDIO Bus: probed
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.253302] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.253761] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.253880] tun: Universal TUN/TAP device driver, 1.6
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.253883] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.254951] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.254953] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.255014] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.255016] igb: Copyright (c) 2007-2014 Intel Corporation.
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.255061] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.255063] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.255129] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.255131] Copyright(c) 1999 - 2017 Intel Corporation.
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.256911] eqos 2490000.ether_qos: no PHY interrupt found
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.261011] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b cb df e1
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.261165] libphy: dwc_phy: probed
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.264234] PPP generic driver version 2.4.2
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.264555] PPP BSD Compression module registered
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.264558] PPP Deflate Compression module registered
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.264576] PPP MPPE Compression module registered
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.264581] NET: Registered protocol family 24
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.264658] usbcore: registered new interface driver r8152
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.264719] usbcore: registered new interface driver asix
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.264779] usbcore: registered new interface driver ax88179_178a
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.264819] usbcore: registered new interface driver cdc_ether
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.264855] usbcore: registered new interface driver net1080
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.264909] usbcore: registered new interface driver cdc_subset
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.264947] usbcore: registered new interface driver zaurus
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.265034] usbcore: registered new interface driver cdc_ncm
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.265316] VFIO - User Level meta-driver version: 0.3
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.267186] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.267202] ehci-pci: EHCI PCI platform driver
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.267248] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.267257] ohci-pci: OHCI PCI platform driver
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.267296] ohci-platform: OHCI generic platform driver
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.275138] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.275144] tegra-xusb 3610000.xhci: USB3 port 2 has OTG_CAP
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.278529] Could not get extcon-dev /xhci@3610000:id(0)
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.282264] usbcore: registered new interface driver uas
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.282387] usbcore: registered new interface driver usb-storage
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.282571] usbcore: registered new interface driver usbserial
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.286752] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.286805] Could not get extcon-dev /xudc@3550000:vbus(0)
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.289945] ucsi_ccg 1-0008: FW1 Version: gn v12.05, [Base 3.1.2.1487]
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.289954] ucsi_ccg 1-0008: FW2 Version: gn v12.05, [Base 3.1.2.1487]
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.291101] ucsi_ccg 1-0008: fw_mode: 2
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.291106] ucsi_ccg 1-0008: fw1_invalid: 0
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.291110] ucsi_ccg 1-0008: fw2_invalid: 0
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.291115] ucsi_ccg 1-0008: silicon_id: 0x1f00
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.291359] ucsi_ccg 1-0008: typec-port0 extcon dev created
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.291531] ucsi_ccg 1-0008: typec-port1 extcon dev created
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.291678] ucsi_ccg 1-0008: typec-pd extcon dev created
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.291852] gpio tegra-gpio-aon wake48 for gpio=10(BB:2)
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.297624] ucsi_ccg 1-0008: HPI Command Success.
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.300121] ucsi_ccg 1-0008: HPI Command Success.
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.300146] ucsi_ccg 1-0008: ucsi_ccg_init: complete
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.300984] mousedev: PS/2 mouse device common for all mice
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.301082] usbcore: registered new interface driver xpad
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.436328] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.438369] Wake73 for irq=42
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.439897] rtc rtc1: alarm rtc device
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.439915] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.439953] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.440201] i2c /dev entries driver
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.445421] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.450789] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.451250] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 2 not supported
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.454643] tegra-thermal-throttle bthrot_cdev: clk:cpu max:2265600000, min:115200000 steps:28
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.509052] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1377000000, min:114750000 steps:13
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.509091] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.509098] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.509439] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:56 cutoff:0
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.509528] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.509588] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.510084] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:52 cutoff:1
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.510235] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.510243] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.510670] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:56 cutoff:0
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.510783] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.510823] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.511280] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.511414] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.511420] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.511842] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:52 cutoff:1
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.512692] FAN dev name: pwm-fan
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.512768] FAN:gpio request success.
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.512812] FAN: can’t find tach_gpio
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.512855] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.513221] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.513266] pwm_fan_driver pwm-fan: tach period: 1000
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.513695] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.513703] pwm_fan_driver pwm-fan: index 1: pwm=77, rpm=1000, rru=2, rrd=2, state:2
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.513709] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.513748] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.513753] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
Jun 21 14:41:47 nvidia-xavier kernel: [ 4.513759] pwm_fan_driver
You could upload the attachment on your post. There is a button on upper-right corner.
Hi Wayne,
I found https://devtalk.nvidia.com/default/topic/1043347/announcements/attaching-files-to-forum-topics-posts/ says there is a button for attachment but I am sorry that I can not see the attachment button while writing the message。
Is it possible that I am not the topic creator?
Thanks,
Tien-Kuen
The button would be shown “after” you file a new comment, so you need to write the message first, file it and then click the button.
OK, let me try again. Two log files 7zipped.
kern.7z (18.2 KB)
syslog.7z (53.7 KB)
Hello Wayne,
Did you get the log files? Is there any update?
Thanks,
Tien-Kuen
Can you please attach ‘sudo lspci -vvvv’ output when you connect them to PCIe slot through the adapter?
If you see that the PCIe link width is x2 when connected to PCIe slot, can you please edit ‘num-lanes’ property of the PCIe node to ‘2’ and try again?
In this case, NVMe slot (M.2 Key-M) is owned by the PCIe controller node ‘pcie@14180000’. Please edit ‘num-lanes’ property of this node to ‘2’.
Hello Wayne,
Please find the attachment of lspci output.
Tien-Kuen
lspci-output.txt (6.6 KB)
Hello Wayne,
I found that the worked WD SSD is PCIe 2-lane device, while both of my SSDs are 4-lane devices.
Regards,
Tien-Kuen
Did you try the suggestion mentioned in #11?
No, Would tell me which file to modify or which document to refer for that?
Thanks,
Tien-Kuen
Please download the kernel source from our download center and follow up the steps in L4T developer guide for #11.
