Only solution I found was to re-install Create. I did that like 5 times.
Is this a know bug? Or is there a keyboard command or menu item to show / hide this UI element?
@pekka.varis - I know this is a hard question, but was there any actions that seem to initiate this loss of the widget? (file saves, drag/drop, load of extension, etc.)
Also was there any other issue at this time, specifically the loss of the ability to mouse click an asset?
Note: Timeline can be toggled on/off. If this happens again, can you check this status and perhaps manually toggle off/on
