I need help to jetson tx2
Hello, I’m from Mexico and I need help with a Jetson tx2 system. I was trying to run a code cloned from Github for object detection, which I couldn’t run due to a camera error that was detecting it. I disconnected the camera module and reconnected it. and when I turned on the device the following message appeared and the screen flashed
4.0549733 pea9520 32-0024: pca9570 _urite_reg: 12c write failed, 0.24 = 0
4.1301321 pea9570 32-0024: pra9570 _urito_reg:12o write failed, 0x24 = 48
1-210763] pa9520 32-0024: pa9570_uxite reg iRe write failed, 0.24
4.34006?1 peo9570 32-0024: pea9570 _urite_reg: t2e write failed, 0x24 - 1.3539771 pen9570 32-0024: pra9570 unite regi12o write failed, 0x21
48
3 10
4.471130] pca9570 32-0024: pca9570 _urite_reg: 12c write failed, 0x24 = 48
4.4783431 pca3570 32-0024: pra9570 _urite_reg: 12c write failed, 0×24
1.5951851 pca9570 32-0024:
pca9570_urite_reg: 12c urite falled, 0×24 = 48
4.602210] pca9520 32-0024: pca9570 _urite_reg: 12c write failed, 0×24 = 0
4.6095531 pea3570 32-0024: pra9570_ ier_pouc!12c urite failca
1.6194173 raa462113 31-0036: raa62113.
Lurite_reg16: 12c write failed, Oxa = 2
4.6221211 raa62113 31-0036: raa462113 write_reg16: 12c write failed, Oxe
4dle
1.6350311 ran162113 31-0036: ran162113
_rite_regi6: i2c write failca, 0x16
230
1.612995] raaf62113 31-0036: raad62113_rite_reg16: I26 write failed, 0x12
4.6507941 raa462113 31-0036: raa162113 write regl6: 12c write failed, Oxa
1.6596611 raa162113 32-0036: ran162113 urite_reg16: 126 write falled, Oxa
4.667382) raa462113 32-0036: raal62113 write_reg16: 12c write failed, @xe = 4d1e
1.6753561 raa162113 32-0036: raa162113_urite_regi6: 12c write failed, Ox16
= 230
1.683322) raa162113 32-0036: raaf62113_write_reg16: 12c write falled, Ox1z
4.6912491 raa462113 32-0036: raaf62113 write_reg161 126 write lalled, @xa -
ep: not uriting through dangling symlink etc/resolu.conf
5.8803101 egroup: cgroup2: unknown option
“'nsde legate”
?.1193061 using randon self ethernet address
1112911 using random host ethernet address
7.828438) using randon self ethernet address
7.8576671 using random host chernet address
7.9374751 CPU1: shutdoun
2.9925981 CPU2: shutdown
10.2732171 uad-lus: voltage opcration not allouca
10.2732673 slici-tegra 3440000 .sdhc1 : could not set regulator OCR (-1)
10.2330193 udd-1u: voltage operation not allowed
10.2930111 sálici-tegra 3110000 .schel: could not set regulator OCR (-1)
10.3139223 wad-100: voltage operation not alloned
10.3133121 salici-tegro 3140000 ,sdhoi: could not set regulator OCR (-1)
10.3161873 vad-10s: voltage operation not alloved
10.3165031 sdici-tegra 3440000 ,sdhcli could not set regulator OCR (-1)
10.1287913 udd-108: voltage operation not alloued
10.4288191 slici-tegra 3440000 ,sdhici;
could not set regulaton OCR (-1)
10.422324) udd-lu0: voltage operation not alloved
10.1299173 salici-tegra 3110000, schel: could not set regulator OCR (-1)
10.4316739 wad-lus; voltage operation not alloued
10.1316083 salici-tegra 3110000 ,schol; could not set ragulator OCR (-1)
This error tell the i2c error. Suppose it could be HW problem.
Try to remove the camera to check if still screen flashed.
I already tried removing the camera module and it’s still the same, the screen keeps flashing :(
Looks like something wrong for the TX2.
Maybe reflash the whole system to confirm.
How can I update the system?
Use sdkmanager to flash it.
