I want to ask some questions about I2C on AGX xavier
Hi,I want to ask some questions about I2C on camera expansion connector (J509) AGX xavier(P2822). I have read pinmux spreadsheets and schematic of P2822 ,I want to confirm some details.
Q1: As shown in fig3 PIN75 and PIN77(I2C3_CLK and I2C3DAT) are Bidir, when PIN75 and PIN77 are use to connect max9296 in 1.8V, whether external pull-up resistance is required. Fig1 shows external pull-up resistance of I2C3 are NC. Could you give me some advices whether external pull-up resistance is required?
Q2: As mentioned above,I2C2 and I2C4(PIN87 89 105 107 IN J509) are use to connect max9296 in 1.8V, whether external pull-up resistance is required?
Q3:As shown in fig4,I want to extend I2C using TCA9546,which I2CBUS is better matched?
Q4: As shown in fig4, voltage of I2C2-4 in J509 and max96712 are 1.8V, I think level shift (3.3-1.8v) is ‘Wrong use’?
I am looking forward to your reply, thank you
question for xavier I2C.rar (524.1 KB)
For external pull-ups, it depends on the total load capacitance on I2C bus. If the load capacitance is much higher than expected, then a stronger pull-up might be necessary. So you can keep the pull-up resistors as NO STUFF in case you want to tune the pull-up strength accordingly.
CAM_I2C is always preferred.
Which doc is the figure 4 from? You can refer to below doc for camera design:
https://developer.nvidia.com/embedded/dlc/jetson-agx-xavier-series-camera-module-hardware-design-guide
Thank you so much
fig4 is from page 24 from ‘Log in | NVIDIA Developer’. I think level shifters connected TCA9548 are not necessary
from jetson-agx-xavier-series-camera-module-hardware-design-guide
