Pull Up on Force Recovery
does the pin FORCE_RECOVERY_N requires an external pull-up resistor or not?
The product design guide v2.4 mentions that there is a pull-up on the module:
However, the line was removed in v2.5 (without any obvious comment why it was removed):
In our design, the pin is connected to a button (pulling to GND) and a GPIO (open-drain) of an MCU. We are using Jetson AGX Xavier and Jetson AGX Xavier Industrial with this carrier board design.
Can you please clarify if an external pull-up is required or if there is a pull-up on the module? If there is one on the module, how strong is the pull-up?
Thanks in advance!
Greetings.
There is a 10k pull-up on module.
