I would like to do ShareIO with ConnectX-5 MT27800 between two servers, but, the second server which has Auxiliary Card installed cannot be ping by other server.
Informations of he first server :
[root@node305 ~]# lspci | grep -i mellanox
06:00.0 Infiniband controller: Mellanox Technologies MT27800 Family [ConnectX-5]
06:00.1 Infiniband controller: Mellanox Technologies MT27800 Family [ConnectX-5]
[root@node305 ~]# ibstatus
Infiniband device ‘mlx5_0’ port 1 status:
default gid: fe80:0000:0000:0000:9803:9b03:0056:2e3a
base lid: 0x1ef
sm lid: 0xa7
state: 4: ACTIVE
phys state: 5: LinkUp
rate: 100 Gb/sec (4X EDR)
link_layer: InfiniBand
Infiniband device ‘mlx5_1’ port 1 status:
default gid: fe80:0000:0000:0000:9803:9b03:0056:2e3b
base lid: 0xffff
sm lid: 0x0
state: 1: DOWN
phys state: 3: Disabled
rate: 10 Gb/sec (4X)
[root@node305 ~]# mlxconfig -d /dev/mst/mt4119_pciconf0 q
Device #1:
Device type: ConnectX5
Description: Mellanox ConnectX-5 Shared IO EDR IB/100GbE Adapter Kit
Device: /dev/mst/mt4119_pciconf0
Informations of he second server :
ibstatus
default gid: fe80:0000:0000:0000:9803:9b03:0056:2e3e
base lid: 0xffff
sm lid: 0xa7
state: 1: DOWN
default gid: fe80:0000:0000:0000:9803:9b03:0056:2e3f
base lid: 0xffff
sm lid: 0x0
state: 1: DOWN
[root@node307 ~]# mlxconfig -d /dev/mst/mt4119_pciconf0 q
Device #1:
It may miss any parameters to activate the ShareIO.
Can you help please ?
Thank you!
Hi Giang,
It would be great if you could provide the following information:
  1. What is the PSID and firmware version of the card? You can run the following commands to fetch the information. Please provide entire output:
#mst start
#mst status (To get MST device name)
#flint -d q
  1. What is the P/N of the cable?
  2. Have you tried connecting it to other switch port? (It looks like link itself is not up)
  3. Please provide the output of : #mlxlink -d -emc
  4. Please provide the output of “#ip addr” from both servers.
Thanks,
Namrata.
Hi Namrata,
Thank you for your answer.
Please find below informations needed :
[root@node305 ~]# flint -d /dev/mst/mt4119_pciconf0 q
Image type: FS4
FW Version: 16.25.6000
FW Release Date: 26.6.2019
Product Version: 16.25.6000
Rom Info: type=UEFI version=14.18.20 cpu=AMD64
type=PXE version=3.5.702 cpu=AMD64
Description: UID GuidsNumber
Base GUID: 98039b0300562e3a 12
Base MAC: 98039b562e3a 12
Image VSD: N/A
Device VSD: N/A
PSID: LNV0000000012
Security Attributes: secure-fw
[root@node307 ~]# flint -d /dev/mst/mt4119_pciconf0 q
Image type: FS4
Image VSD: N/A
Device VSD: N/A
PSID: LNV0000000012
continue…
[root@node305 ~]# mlxlink -d /dev/mst/mt4119_pciconf0 -emc
Operational Info
State : Active
Physical state : LinkUp
Speed : IB-EDR
Width : 4x
FEC : Standard LL RS-FEC - RS(271,257)
Loopback Mode : No Loopback
Auto Negotiation : ON
Supported Info
Enabled Link Speed : 0x0000003f (EDR,FDR,FDR10,QDR,DDR,SDR)
Supported Cable Speed : 0x0000003f (EDR,FDR,FDR10,QDR,DDR,SDR)
Troubleshooting Info
Status Opcode : 0
Group Opcode : N/A
Recommendation : No issue was observed.
Physical Counters and BER Info
Time Since Last Clear [Min] : 25.6
Effective Physical Errors : 0
Raw Physical Errors Per Lane : 0,0,0,0
Effective Physical BER : 15E-255
Raw Physical BER : 15E-255
EYE Opening Info
Physical Grade : 39730, 43882, 36409, 37563
Height Eye Opening [mV] : 128, 131, 130, 126
Phase Eye Opening [psec] : 12, 13, 12, 12
Module Info
Identifier : QSFP+
Compliance : N/A
Cable Technology : Copper cable unequalized
Cable Type : Passive copper cable
OUI : Mellanox
Vendor Name : Mellanox
Vendor Part Number : 00MP561
Vendor Serial Number : 2P56196LZ52
Rev : B1
Attenuation (5g,7g,12g) [dB] : 6,8,12
FW Version : N/A
Wavelength [nm] : N/A
Transfer Distance [m] : 3
Digital Diagnostic Monitoring : No
Power Class : 1.5 W max
CDR RX : OFF,OFF,OFF,OFF
CDR TX : OFF,OFF,OFF,OFF
LOS Alarm : N/A
Temperature [C] : N/A
Voltage [mV] : N/A
Bias Current [mA] : N/A
Rx Power Current [dBm] : N/A
Tx Power Current [dBm] : N/A
[root@node307 ~]# mlxlink -d /dev/mst/mt4119_pciconf0 -emc
Operational Info
State : Active
Speed : IB-EDR
Width : 4x
Supported Info
Status Opcode : 0
Group Opcode : N/A
Time Since Last Clear [Min] : 26.8
EYE Opening Info
Module Info
Identifier : QSFP+
Compliance : N/A
OUI : Mellanox
Rev : B1
FW Version : N/A
LOS Alarm : N/A
Voltage [mV] : N/A
continue…
[root@node305 ~]# ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 08:94:ef:90:aa:da brd ff:ff:ff:ff:ff:ff
inet 10.120.37.41/22 brd 10.120.39.255 scope global eth0
3: eth1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 08:94:ef:90:aa:db brd ff:ff:ff:ff:ff:ff
4: ib0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 2044 qdisc mq state UP group default qlen 256
link/infiniband 20:00:10:86:fe:80:00:00:00:00:00:00:98:03:9b:03:00:56:2e:3a brd 00:ff:ff:ff:ff:12:40:1b:ff:ff:00:00:00:00:00:00:ff:ff:ff:ff
inet 10.135.37.41/22 brd 10.135.39.255 scope global ib0
5: ib1: <BROADCAST,MULTICAST> mtu 4092 qdisc noop state DOWN group default qlen 256
link/infiniband 20:00:18:86:fe:80:00:00:00:00:00:00:98:03:9b:03:00:56:2e:3b brd 00:ff:ff:ff:ff:12:40:1b:ff:ff:00:00:00:00:00:00:ff:ff:ff:ff
6: eth0.2705@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 10.120.41.41/22 brd 10.120.43.255 scope global eth0.2705
[root@node307 ~]# ip addr
link/ether 08:94:ef:90:a4:de brd ff:ff:ff:ff:ff:ff
inet 10.120.37.43/22 brd 10.120.39.255 scope global eth0
link/ether 08:94:ef:90:a4:df brd ff:ff:ff:ff:ff:ff
4: ib0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 4092 qdisc mq state DOWN group default qlen 256
link/infiniband 20:00:14:86:fe:80:00:00:00:00:00:00:98:03:9b:03:00:56:2e:3e brd 00:ff:ff:ff:ff:12:40:1b:ff:ff:00:00:00:00:00:00:ff:ff:ff:ff
inet 10.135.37.43/22 brd 10.135.39.255 scope global ib0
link/infiniband 20:00:1c:86:fe:80:00:00:00:00:00:00:98:03:9b:03:00:56:2e:3f brd 00:ff:ff:ff:ff:12:40:1b:ff:ff:00:00:00:00:00:00:ff:ff:ff:ff
inet 10.120.41.43/22 brd 10.120.43.255 scope global eth0.2705
  1. The switch port seems be ok, ping from another server to the primary Mellanox Card works which is connecte to node305.
But the same ping to the Auxiliary Card which is connecte to node307 does not work.
Thanks,
Giang
Hi Giang,
Based on the output of “ip addr” from node 307, the status of ib0 shows it is down:
whereas from node 305, it is UP:
Are you using Mellanox Driver(MLNX OFED)? You can verify by running "#[Ofed_info -s]​ "
In addition, I would like to clarify that based on the output provided for the “flint” command, the cards are Lenovo branded(PSID LNV0000000012). Thus, when OEM(in this case Lenovo) cards are involved, our general policy is that end customer needs to open a case with OEM and if required OEM will open a case with us. We do not communicate with end customer directly when OEM cards are involved.
Thanks,
Namrata.
