IGX Thor Dev Kit and Storage / Connect-X 7
I am considering a PoC for local inference using an IGX Thor. One thing that we might want is to have more storage.
Therefor:
  • is there a list of supported PCIE SSDs with higher capacity ? (like 4 TB or so)
  • Is there an option to hook up SATA HDDs ?
  • Does IGX-SW (and the IGX Thor) support SAS via a PCI-E controller ?
  • Can the Connect-X 7 be used to connect 2 IGX Thor Dev Kits the same way I can hook up 2 DGX Sparks tun run inference across both nodes ? Are the commands the same ?
Thank you
1. Supported PCIe SSDs with higher capacity Currently, the IGX Thor Dev Kit Supported Components List (SCL) includes a single 1TB NVMe SSD. There is no qualified list of higher-capacity (e.g. 4TB) PCIe SSDs at this time.
2. SATA HDD connectivity Yes. According to the NVIDIA IGX T7000 Product Specification, the IGX Thor Dev Kit provides four SATA connectors on the carrier board, so you can connect SATA drives for additional storage.
3. SAS via PCIe controller Third-party PCIe SAS controllers (HBAs) have not been validated on the IGX Thor platform. We only officially support the components listed in the Supported Components List (SCL).
4. Connecting two IGX Thor Dev Kits via ConnectX-7 for multi-node inference this configuration has not been validated on the IGX Thor Dev Kit.
For reference, both the Product Specification and SCL documents are available at the IGX Download Center.
Thank you.
