IGX Thor Broken
I have a early access IGX - THOR development system the URL provided “https://www.nvidia.com/igx-thor-start” goes to page not found
Could you take a picture of the developer kit? Would like to confirm which device you are using.
here is the image of the dev kit and the doc i received
2026-01-14T06:00:00Z
Hi vince.potenzone,
Have you used IGX Orin before?
If so, it should be the similar steps to setup for IGX Thor.
Please refer to NVIDIA IGX Orin User Guide — NVIDIA IGX Orin - User Guide before the official IGX-SW-2.0 GA release(which is supposed for IGX Thor)
You can simply plug the power and the DP port to check if there’s any output on the display.
