IGX Thor EA Unable to boot
Hi I had received an IGX Thor a month ago and have been trying to get it online.
Trying to go to the Documentation based on the provided booklet seems to give me a Page Not Found error.
Then after doing some searches it lead me to another post that states to follow the same setup procedure as the IGX Orin.
When heading over to that page, connecting a Display Adapter via a DisplayPort connecter to the GPU yields this issue:
I’m not able to see any login screen or any UEFI bootup protocol. The only thing that appears after booting up the device from this stage: Installing IGX-Software on IGX 700 or IGX Developer Kit — NVIDIA IGX Orin - User Guide
Next step was to try and see if I could access the BMC via ethernet. I was able to perform an ssh root@192.168.1.110, but the password doesn’t seem to be the default that was given on the IGX Orin website.
Any help on this matter would be appreciated
Hi victor.lian,
Are you using IGX Thor developer kit?
Please refer to the Release Notes in IGX SW 2.0EA package to setup.
Please check if the password has been modified by others before you use this board.
