Igx_sw_2.0_ea on IGX Thor T7000 installation
I have tried to install igx_sw_2.0_ea on IGX Thor T7000 without success. Following the guide inside the SW package, I flashed an USB drive with the ISO. The installation starts but gets stuck with the log below (from IGX UART).
  • Does igx_sw_2.0_ea supports IGX Thor T7000?
  • Any suggestion what could be the problem?
Thanks,
Rogerio
[ 14.711702] audit: type=1400 audit(1752259981.616:11): apparmor=“STATUS” oper
ation=“profile_load” profile=“unconfined” name=“ch-run” pid=1281 comm=“apparmor_
parser”
[ 14.840765] iscsi: registered transport (iser)
[ 15.958393] at24 1-0050: supply vcc not found, using dummy regulator
[ 15.960065] at24 7-0055: supply vcc not found, using dummy regulator
[ 16.130522] ina2xx 3-0044: supply vs not found, using dummy regulator
[ 16.941248]
[ 19.444974] block nvme0n1: No UUID available providing old NGUID
��INFO: END TASK:MB��
INFO: enter idle task.
INFO: END TASK:MB��
��ph =��ter idle ta��GPC ��sk.
��> logic map: 0=>0 1=>2 2=>1
��[ 21.702953] nvidia 0000:01:00.0: [drm] No compatible format found
[ 23.461841] [drm:nv_drm_dev_load [nvidia_drm]] ERROR [nvidia-drm] [GPU ID �
�RmDe��0x00��Init��0200�� com��00] ��plet��Fail��ed s��ed t��ucce��o al��ssfu��l
��te N��
��vKmsKapiDevice
[ 23.461885] [drm:nv_drm_register_drm_device [nvidia_drm]] ERROR [nvidia-drm
] [GPU ID 0x00020000] Failed to load device
[ 23.510618] Please complete NVIDIA OOBE on the serial port provided by Jetson
's USB device mode connection. e.g. /dev/ttyACMx where x can 0, 1, 2 etc.
��GPC ph => logic map: 0=>0 1=>2 2=>1
��[ 30.189761] platform regulator-vdd-3v3-dp: deferred probe pending: platform
: wait for supplier /regulator-vdd-3v3-sys
It seems the installation has been completed and you have to connect the display and mouse/keyboard to setup for the username/password/hostname..etc in first boot.
Hi Kevin,
Yes, you’re right. The installation was successfuly completed. I was able to create an user and login using UART terminal. I had thought the installation wasn’t completed because the display is not working (the same happens on JetPack 7.0).
When Using JetPack 7.0, I was able to disable the NVIDIA DRM driver and use the open source driver to make display work. I’m trying now to do the same on IGX-OS 2.0.
If you have some clue how to fix the display driver, please let me know.
Rogerio
As you are using IGX SW 2.0 EA, there may be some issues have not been fixed yet or the system is unstable.
I would suggest waiting for the upcoming IGX SW 2.0 GA to verify for display issue.
If you still have display issue, please help creating another topic to discuss in details.
Just to confirm. The IGX-OS 2.0 production release fixed the display.
Thanks,
Rogerio
