after reflash, when the IGX Orin Developer Kit works with RTXA6000 and connect to its DP display output port, it doesn’t have signal. but after I remove the RTXA6000 and connect to the orin DP Display port.the kit can enter the os normally.
jinl
2
Hi there, for devkit getting started questions, please utilize our IGX forum to receive the best support. IGX Developer Kit - NVIDIA Developer Forums
Related topics
| NO DP signal after IGX orin system reboot | 24 | 819 | September 6, 2024 | |
| GX Orin does not detect RTX A6000 Ada / no output from dGPU DisplayPort | 13 | 111 | April 27, 2026 | |
| IGX dev board is booting up, but not getting display via DP or HDMI cable | 16 | 561 | June 6, 2024 | |
| Orin DP is not working | 17 | 1935 | March 13, 2023 | |
| DP port on Orin can't work | 2 | 908 | February 20, 2023 | |
| New AGX Orin - No Display using DP <-> DP cable | 5 | 1501 | November 7, 2022 | |
| AGX ORIN Display Not Coming though working Perfectly in remote SSH | 4 | 921 | June 20, 2023 | |
| Display Problem | 13 | 1276 | June 12, 2023 | |
| Displal port no signal error | 4 | 100 | April 22, 2025 | |
| No DP Signal error | 8 | 906 | June 21, 2023 |
