on a custom yocto image built for Xavier NX, despite trying all I could think of and checking and re-checking that everything is in place, the 6050 driver simply will not load and/or create the /sys/bus/iio/device entry
device tree contains the right entry, kernel module exists…
Am really looking for constructive suggestions. have scouted the web and could only find kernel config entries suggestions but looking closer these apply to FPGAs which is not helping.
Thanks in advance for your help
Hi Patrick,
I took the liberty of moving your post to the appropriate Jetson forums for better exposure.
Reference to below document to add necessary code to device tree.
…/kernel/kernel-5.10/Documentation/devicetree/bindings/iio/imu/inv_mpu6050.txt
Found out that my predecessor on the project used a kernel that knew nothing about that particular chip so I have to back port support for that chip in the kernel
That should sort that out. :-)
Making progress, backport succesful and driver now loading .
Sending 0x98 to the chip and receiving 0x0 which probably means miscommunication on SPI bus
Could be the clk used in device tree
Any suggestion once more welcome…
You may need configure the SPI pins by jetson-io to enable SPI.
