Software Version
DRIVE OS 7.0.3
other
Target Operating System
Linux
QNX
other
Hardware Platform
DRIVE AGX Thor Developer Kit (940-63960-0010-000)
DRIVE AGX Thor Developer Kit (940-63960-0012-000)
other
Host Machine Version
native Ubuntu Linux 24.04 Host installed with DRIVE OS Docker Containers
other
Issue Description:
Running the stock `nvm_ijpe_sci` sample (`/drive/drive-linux/samples/nvmedia_6x/ijpe/`) prints these two lines per encode submission, regardless of the sample’s own `-v` log level:
TEST: Append a pushbuffer with channel's syncpoint increment ********
GOT VALID FENCES
Repro:
./nvm_ijpe_sci -f fisheye_1280_1080_yuv420.yuv -pf 1 -fr 1280x1080 -q 50 -of /tmp/out.jpg
We found that NvMediaIJPEFeedFrame(), NvMediaIJPEFeedFrameQuant(), and NvMediaIJPEFeedFrameRateControl() all print this, regardless of which one is used.
Questions:
1. Is this expected/intentional debug output in `libnvvideo.so`, or a bug (looks like leftover test/debug logging, given the string literally says “TEST:”)?
2. If it’s a known issue, which DRIVE OS version has it fixed/removed?
3. Is there any supported way to disable it (env var, log-level API, config)?
