Found CUDA: C:/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2 (found version "11.2")
-- Caffe2: CUDA detected: 11.2
-- Caffe2: CUDA nvcc is: C:/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/bin/nvcc.exe
-- Caffe2: CUDA toolkit directory: C:/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2
-- Caffe2: Header version is: 11.2
-- Could NOT find CUDNN (missing: CUDNN_LIBRARY_PATH CUDNN_INCLUDE_PATH)
CMake Warning at libtorch/share/cmake/Caffe2/public/cuda.cmake:111 (message):
Caffe2: Cannot find cuDNN library. Turning the option off
Call Stack (most recent call first):
libtorch/share/cmake/Caffe2/Caffe2Config.cmake:88 (include)
libtorch/share/cmake/Torch/TorchConfig.cmake:68 (find_package)
CMakeLists.txt:4 (find_package)
-- C:/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.2/lib/x64/nvrtc.lib shorthash is 06d01f09
-- Autodetected CUDA architecture(s): 8.6 8.6 8.6 8.6 8.6 8.6 8.6
-- Added CUDA NVCC flags for: -gencode;arch=compute_86,code=sm_86
CMake Warning (dev) at libtorch/share/cmake/Caffe2/public/cuda.cmake:467 (if):
Policy CMP0054 is not set: Only interpret if() arguments as variables or
keywords when unquoted. Run "cmake --help-policy CMP0054" for policy
details. Use the cmake_policy command to set the policy and suppress this
warning.
Quoted variables like "MSVC" will no longer be dereferenced when the policy
is set to NEW. Since the policy is not set the OLD behavior will be used.
This warning is for project developers. Use -Wno-dev to suppress it.
CMake Error at libtorch/share/cmake/Caffe2/Caffe2Config.cmake:96 (message):
Your installed Caffe2 version uses cuDNN but I cannot find the cuDNN
libraries. Please set the proper cuDNN prefixes and / or install cuDNN.
I have the same problem, did you find a solution?
