Share the full dmesg, dts and which software release you are using.
I am attaching the full dmesg.
dmesg4.txt (124.6 KB)
Is dts referring to the dtsi I modified?
What do you mean by software release?
Are you talking about the L4T version?
Thank you.
Use dtc tool to convert the dtb back to dts. You will see a single file that contains all the device tree. Unlike the source code, which includes lots of dtsi files.
Yes
dts is attached.
tegra210-p3448-0002-p3449-0000-b00.dts (326.9 KB)
L4T version :
cat /etc/nv_tegra_release
R32 (release), REVISION: 5.1, GCID: 26202423, BOARD: t210ref, EABI: aarch64, DATE: Fri Feb 19 16:45:52 UTC 2021
Thank you.
add cd-gpios and assign the gpio which matches your hardware design.
This topic is totally same as your case. Just read it first.
Hello, @WayneWWW @emreanilterzioglu
How can I add cd-gpios ?
adding it from the dtsi file?
Thank you.
Yes, adding it to the dts.
I have multiple dtsi files, can you specify which file to add?
Thank you.
Do you understand the rule of how device tree works?
I don’t know much right now, but I can follow along as I learn.
I only know the term open platform.
Can you briefly explain how to add it?
Thank you.
I don’t quite understand the article below, where you pointed out that this is a similar case to mine.
Thank you.
Ok, then maybe this thread is shorter so that you can understand it easily.
This guy is also doing the debug. Maybe you can refer to it first so that I don’t need to write the same thing twice.
Thank you 👍
After adding cd-gpios and building dtb as shown in the first picture below, even if applied to nano, dmesg output is displayed as in the second picture below.
Which part should I check?
I am attaching dts made with dtc.
tegra210-p3448-0002-p3449-0000-b00.dts (327.0 KB)
I am attaching a full dmesg log.
dmesg_result.txt (63.9 KB)
I found the following in dmesg:
Thank you.
Hello
First of all, without using dtsi.
Is it possible to test the SD card by using the command to temporarily change gpio08(FAN_TACH) to SDMMC to make GPIO08 operate as SDMMC?
Can you please tell me how to do it?
Thank you.
NOT POSSIBLE. It is time for you to learn how to develop such thing. If you don’t know how to use device tree, why not just start from building the original dts and flash it to board first?
Is it correct to configure pinmux using a spreadsheet as follows?
If yes, can you tell me how to set it to SDMMC3_CD here?
Thank you.
You are just asking the same question as this post doing. Thus, you can just check my answer in this comment.
