Image segmentation sample in driveworks 5.14
Is there any sample provided for Image Segmentation in Driveworks 5.14 on Drive Orin?
Dear @akshay.tupkar,
We don’t have segmentation sample. However, you could check integrating model using DNN framework.
The DNN samples provided with DW can be found at DriveWorks SDK Reference: Samples
Dear @SivaRamaKrishnaNV
I came across a sample named “Connected Components” in driveworks which seems like segmentation
It is not a DNN based segmentation(like UNet) but based on image processing techniques. It demonstrates the connected components module API usage. Image gets divided into different group of pixels based the intensities. If you plan to check segmenting the image with pedestrian/vehicles and different set of classes etc, it may not work optimally. Please see if it fits your requirement.
