Impossible to post issues to https://github.com/NVIDIA/CloudXR
We discovered an issue and we wanted to post an issue on the github, but it seems the repository (GitHub - NVIDIA/CloudXR: CloudXR sample applications for streaming AR/VR/MR content from the cloud) doesnt allow external developers to post issues.
Specifically it is in this file:
On line 184 it is currently like this:
AddOption("enable-ir-decoder", "ird", false, "Enable experimental ImageReader decoder on Android devices (reqs sdk >= 26)",
HANDLER_LAMBDA_FN{ mDebugFlags |= cxrDebugFlags_EnableImageReaderDecoder; return ParseStatus_Success; });
When it was like that it wasn´t possible to build it.
Commenting it out didn´t help
But when changed to to:
AddOption("enable-ir-decoder", "ird", false, "Enable experimental ImageReader decoder on Android devices (reqs sdk >= 26)",    HANDLER_LAMBDA_FN{ mDebugFlags |= cxrDebugFlags_EnableAImageReaderDecoder; return ParseStatus_Success; });
Then it worked on CloudXR 3.2 (From May 2022).
I realize this response is quite dated, but wanted to post something. :)
If all other lines were fine, there’s nothing special about that particular line that should be causing a compiler issue. I’d need to know the compiler, any specific options, and see output from build log, to even have a sense of what your particular setup is having issues with.
Eliminating the line break should have zero impact, else every line in the file would be throwing an error…
As for reporting on github, there have been many conversations over the past year about how to better engage on github, and it is possible we’ll eventually get to having issues and PRs and such, but for now it’s just a distribution point.
Reporting of issues can be done through your original contact for CloudXR, or via this forum. We’re hoping to expand/improve upon that moving forward, but haven’t had a plan, sign-off, and/or resources to do so as yet. Keep an eye out, hopefully that will change, clearly a forum isn’t great for bug reporting, you need a ‘form’ to fill out specific to CloudXR, prompting you for the information we’d need to help.
