Hi @axel.goedrich,
The bottleneck is not the Python loop itself but USD change notifications. Each call to
GetReferences().AddInternalReference() individually notifies the Kit scene-graph, triggering
a viewport update and a Hydra re-sync. With 8,000 prims that is 8,000 round-trips through the
notification system. Parallelization is not available (the USD stage is not thread-safe for
authoring), but batching is – and the speedup is dramatic.
Fix 1: Wrap the loop in Sdf.ChangeBlock
Sdf.ChangeBlock defers all change notifications until the block exits. The entire loop
fires exactly one consolidated notification at the end instead of 8,000.
from pxr import Sdf
def position_elements_in_racks(elements_path, element_matrix, layout_element):
stage = get_context().get_stage()
palett_root_prim = load_element(
layout_element['pallet']['asset_path'],
layout_element['pallet']['asset_name']
palett_root_path = palett_root_prim.GetPrimPath()
with Sdf.ChangeBlock(): # <-- only change needed
for row in element_matrix:
rack_id = int(row[0])
palett_id = int(row[1])
rack_rot = row[3]
element_pos = row[7:10] + row[4:7]
element_prim_path = f"{elements_path}/element_{rack_id}_{palett_id}"
new_prim = stage.DefinePrim(element_prim_path)
new_prim.GetReferences().AddInternalReference(palett_root_path)
position_prim(new_prim, element_pos, (0, 0, rack_rot - 90))
This is the same technique Isaac Sim uses internally for bulk stage edits (for example,
in the material-deduplication and geometry-routing rules in isaacsim.asset.transformer.rules).
See Sdf.ChangeBlock in the
OpenUSD API docs for details.
Fix 2: Temp-stage + Sdf.CopySpec (zero intermediate notifications)
For even better results, build all prims on a temporary in-memory stage first, then
copy the entire subtree to the live stage in one atomic operation. This is the approach
used by Isaac Sim’s Warehouse Creator extension when generating large warehouse layouts
(see Warehouse Creator):
from pxr import Gf, Sdf, Usd, UsdGeom
ctx = get_context()
live_stage = ctx.get_stage()
# Build on an in-memory stage -- no live notifications whatsoever
temp_stage = Usd.Stage.CreateInMemory()
rack_rot = row[3]
new_prim = temp_stage.DefinePrim(element_prim_path, "Xform")
xf = UsdGeom.Xformable(new_prim)
xf.AddTranslateOp().Set(Gf.Vec3d(*element_pos))
xf.AddRotateXYZOp().Set(Gf.Vec3f(0.0, 0.0, rack_rot - 90))
# Atomic write to live stage: one notification for the whole subtree
elements_path_sdf = Sdf.Path(elements_path)
if live_stage.GetPrimAtPath(elements_path_sdf):
live_stage.RemovePrim(elements_path_sdf)
Sdf.CopySpec(
temp_stage.GetRootLayer(), elements_path_sdf,
live_stage.GetRootLayer(), elements_path_sdf,
Fix 3: SetInstanceable(True) for identical pallet variants
For pallet variants that are visually identical (no per-pallet material overrides or
child-prim visibility differences), mark the prim instanceable:
new_prim.SetInstanceable(True)
This tells Kit’s renderer to treat all instanceable prims referencing the same asset as
a single hardware instance group, cutting GPU draw calls significantly. You cannot use
this for pallets that need individual material swaps or descendant overrides – in those
cases, leave instanceable=False (the default).
If pallets do not need independent per-instance rigid-body simulation
If each pallet does not need to move, collide, or be simulated independently as its own
rigid body, UsdGeom.PointInstancer
is the most efficient option. It stores all 8,000 positions as a single array and renders
with hardware instancing. As the Isaac Sim scripting docs
note, PointInstancer does support physics interaction – instances share the prototype’s
collision and physics properties – but each instance is not a separate simulated body.
from pxr import UsdGeom, Gf, Vt
point_instancer = UsdGeom.PointInstancer(
stage.DefinePrim(f"{elements_path}/pallets", "PointInstancer")
point_instancer.CreatePrototypesRel().SetTargets([palett_root_prim.GetPath()])
point_instancer.CreateProtoIndicesAttr().Set([0] * len(element_matrix))
point_instancer.CreatePositionsAttr().Set(
Vt.Vec3fArray([Gf.Vec3f(*(row[7:10] + row[4:7])) for row in element_matrix])
If each pallet must be an independent rigid body (separate mass, contacts, forces), stick
with Fix 1 or Fix 2 instead.
Summary:
| Approach |
Effort |
Best for |
Sdf.ChangeBlock around loop |
1 line |
All cases; drop-in replacement |
Temp stage + Sdf.CopySpec |
Moderate refactor |
Largest scenes; eliminates all intermediate updates |
SetInstanceable(True) |
1 line (supplement) |
Visually identical variants; cuts GPU draw calls |
UsdGeom.PointInstancer |
Refactor |
Shared physics or visual-only; no independent per-pallet rigid bodies |
Since this topic is stale, we are closing
it now. If you are still working on this or ran into any issues with the approaches above,
please open a new topic
and link back to this one for context.
