Multithreaded loading
I am exploring a workaround for Incorrect BBoxes in BasicWriter output - #43 by Turowicz
Basically I need to load 1000s of instances of the same USD at start, in order to offset the bug with instantization.
Thing is, rep.create.from_usd(usd="file://...",count=NUM_TOTAL_ASSETS) is very slow as it seems to use only a single CPU core.
@pcallender @jlafleche would it be possible to run this in parallel to speed up app start?
Another aspect of that workaround: when having 1000s of instances of a single usd, any kind of randomization operations (chaning materials, colours, etc.) take a lot of time at each interval as there is a massive graph to run the regexes against.
Hello @Turowicz! Accelerating the creation of USD references is something we’ve been actively working on and I’m happy to share a function that you can use now until the next version of Replicator which will integrate this optimization natively. This approach achieve a ~190x speedup
from typing import Optional
import omni.usd
import pxr
def from_usd_fast(
    usd_path: str = None,
    prim_path: str = None,
    parent: Optional[str] = None,
    count: int = 1,
    name: str = "Ref",
) -> rep.utils.ReplicatorItem:
    """Use Prim Specs to create references within an Sdf.ChangeBlock.
    This function is faster than the default create function because it uses Prim Specs to create references within an
    Sdf.ChangeBlock.
    Args:
        usd_path (str): _description_
        prim_path (str): _description_
        parent (Optional[str], optional): _description_. Defaults to None.
        count (int, optional): _description_. Defaults to 1.
        name (str, optional): _description_. Defaults to "Ref".
    Returns:
        rep.utils.ReplicatorItem: _description_
    usd_path = str(usd_path) if usd_path is not None else ""
    prim_path = str(prim_path) if prim_path is not None else pxr.Sdf.Path()
    if parent is None:
        if not stage.GetPrimAtPath(rep.create.REPLICATOR_SCOPE):
            stage.DefinePrim(rep.create.REPLICATOR_SCOPE, "Scope")
        parent = rep.create.REPLICATOR_SCOPE
    xform_paths = []
    prims_paths = []
    suffix = 0
    xform_name = f"{name}_Xform"
    with pxr.Sdf.ChangeBlock():
        for _ in range(count):
            # First create a xform on top of it.
            if suffix == 0:
                xform_path = f"{parent}/{xform_name}"
                suffix += 1
            else:
                xform_path = f"{parent}/{xform_name}_{suffix:02d}"
                suffix += 1
            # Find first available path
            while stage.GetPrimAtPath(xform_path):
                suffix += 1
            spec = pxr.Sdf.CreatePrimInLayer(stage.GetEditTarget().GetLayer(), xform_path)
            spec.typeName = "Xform"
            spec.specifier = pxr.Sdf.SpecifierDef
            # Create the prim
            name = pxr.Tf.MakeValidIdentifier(name)
            ref_prim_path = f"{xform_path}/{name}"
            prim_spec = pxr.Sdf.CreatePrimInLayer(stage.GetEditTarget().GetLayer(), ref_prim_path)
            prim_spec.specifier = pxr.Sdf.SpecifierDef
            xform_paths.append(xform_path)
            prim_spec.referenceList.Prepend(pxr.Sdf.Reference(assetPath=usd_path, primPath=prim_path))
            prims_paths.append(ref_prim_path)
    return rep.create.group(xform_paths)
rep.create.register(from_usd_fast)
Test Script:
import time
N = 5000
ref = rep.example.ASSETS[0]
omni.usd.get_context().new_stage()
print("Starting Standard Test...")
start = time.time()
rep.create.from_usd(ref, count=N)
print("Standard", time.time() - start)
print("Starting Fast Test...")
start = time.time()
rep.create.from_usd_fast(usd_path=ref, count=N)
print("Fast", time.time() - start)
print("Starting Standard Test with positions...")
start = time.time()
refs = rep.create.from_usd(ref, count=N)
with refs:
    rep.modify.pose(position=rep.distribution.uniform((-500, -500, -500), (500, 500, 500)))
print("Standard with positions", time.time() - start)
print("Starting Fast Test with positions...")
start = time.time()
refs = rep.create.from_usd_fast(usd_path=ref, count=N)
with refs:
print("Fast with positions", time.time() - start)
Output on test (N=5000, machine (Ryzen 1700X, Nvidia TitanRTX))
Standard 194.00616669654846
Fast 0.994647741317749
Standard with positions 194.6883668899536
Fast with positions 1.2436614036560059
We shall see tomorrow 🤣
@jlafleche any ideas how to speed up the code for manipulating tints (below) for 1000s of instances? Seems like the regex search is slow.
        # Randomize accessories tints
        with rep.get.shader(path_pattern="hat_tint",cache_result=False):
            rep.modify.attribute(name="inputs:diffuse_tint",
                                 attribute_type="color3f",
                                 value=rep.distribution.choice(choices=neutral()))
        with rep.get.shader(path_pattern="hat_.*_tint",cache_result=False):
        with rep.get.shader(path_pattern="helmet_tint",cache_result=False):
                                 value=rep.distribution.choice(choices=flashy_neutral()))
        with rep.get.shader(path_pattern="helmet_.*_tint",cache_result=False):
        with rep.get.shader(path_pattern="earprotectors",cache_result=False):
        with rep.get.shader(path_pattern="mask_A_tint",cache_result=False):
        with rep.get.shader(path_pattern="hygenic_mask_tint",cache_result=False):
        with rep.get.shader(path_pattern="gloves_tint",cache_result=False):
                                 value=rep.distribution.choice(choices=flashy()))
        with rep.get.shader(path_pattern="glasses_12_lenses",cache_result=False):
            rep.modify.attribute(name="inputs:opacity_constant",
                                 attribute_type="float",
                                 value=rep.distribution.uniform(lower=0.05,
        upper=0.13))
Exactly how slow are you seeing? I ran a small test with 4500 materials and am seeing betweeen 3-4 seconds to run. Does that match up with what you’re seeing?
I will record it for you during the next batch
@jlafleche is there a way to measure how long replicator step took? I’d like to give you solid numbers.
Please find the videos below:
No color randomization (fast):
With color randomization from the above source code pasted:
Now obviously I’ve been using this example with a limited amount of assets. Please let me know what do you think about the performance.
