I am working on LI-IMX274 with Jetson-TX1.
This device’s probe method executed successfully, but I can’t see video0 in the /dev directory.
I can see IMX274 probe method finished with success.
But I see problems with vi, it says
Here is my dmesg output:
[ 6.761133] vi 54080000.vi: vi_probe: ++
[ 6.767770] vi 54080000.vi: initialized
[ 6.771446] vi 54080000.vi: ep of_device is not enabled /host1x/vi/ports/port@0/endpoint.
[ 6.771449] vi 54080000.vi: ep of_device is not enabled /host1x/vi/ports/port@1/endpoint.
[ 6.771452] vi 54080000.vi: ep of_device is not enabled /host1x/vi/ports/port@2/endpoint.
[ 6.771455] vi 54080000.vi: ep of_device is not enabled /host1x/vi/ports/port@3/endpoint.
[ 6.771457] vi 54080000.vi: all channel register failed
I am communicating with LI-IMX274 with using CSI-A, and here is my device tree sources:
tegra210-camera-imx274-a00.dtsi
* Copyright (c) 2016-2017, NVIDIA CORPORATION. All rights reserved.
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful, but WITHOUT
* ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
* FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
* more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
#include <dt-bindings/media/camera.h>
#include <dt-bindings/platform/t210/t210.h>
host1x {
vi {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
liimx274_vi_in0: endpoint {
status = "okay";
csi-port = <0>;
bus-width = <4>;
remote-endpoint = <&liimx274_csi_out0>;
nvcsi {
num-channels = <1>;
#size-cells = <0>;
channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
liimx274_csi_in0: endpoint@0 {
status = "okay";
csi-port = <0>;
bus-width = <4>;
remote-endpoint = <&liimx274_imx274_out0>;
port@1 {
reg = <1>;
liimx274_csi_out0: endpoint@1 {
status = "okay";
remote-endpoint = <&liimx274_vi_in0>;
i2c@546c0000 {
tca9546@70 {
i2c@0 {
imx274_a@1a {
compatible = "nvidia,imx274";
/* I2C device address */
reg = <0x1a>;
/* Physical dimensions of sensor */
physical_w = "3.674";
physical_h = "2.738";
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
avdd-reg = "vana";
iovdd-reg = "vif";
dvdd-reg = "vdig";
/* Defines number of frames to be dropped by driver internally after applying */
/* sensor crop settings. Some sensors send corrupt frames after applying */
/* crop co-ordinates */
/*post_crop_frame_drop = "0";*/
/* if true, delay gain setting by one frame to be in sync with exposure */
delayed_gain = "true";
* A modeX node is required to support v4l2 driver
* implementation with NVIDIA camera software stack
* mclk_khz = "";
* Standard MIPI driving clock, typically 24MHz
* num_lanes = "";
* Number of lane channels sensor is programmed to output
* tegra_sinterface = "";
* The base tegra serial interface lanes are connected to
* discontinuous_clk = "";
* The sensor is programmed to use a discontinuous clock on MIPI lanes
* dpcm_enable = "true";
* The sensor is programmed to use a DPCM modes
* cil_settletime = "";
* MIPI lane settle time value.
* A "0" value attempts to autocalibrate based on mclk_multiplier
* active_w = "";
* Pixel active region width
* active_h = "";
* Pixel active region height
* pixel_t = "";
* The sensor readout pixel pattern
* readout_orientation = "0";
* Based on camera module orientation.
* Only change readout_orientation if you specifically
* Program a different readout order for this mode
* line_length = "";
* Pixel line length (width) for sensor mode.
* This is used to calibrate features in our camera stack.
* mclk_multiplier = "";
* Multiplier to MCLK to help time hardware capture sequence
* TODO: Assign to PLL_Multiplier as well until fixed in core
* pix_clk_hz = "";
* Sensor pixel clock used for calculations like exposure and framerate
* inherent_gain = "";
* Gain obtained inherently from mode (ie. pixel binning)
* min_gain_val = ""; (floor to 6 decimal places)
* max_gain_val = ""; (floor to 6 decimal places)
* Gain limits for mode
* min_exp_time = ""; (ceil to integer)
* max_exp_time = ""; (ceil to integer)
* Exposure Time limits for mode (us)
* min_hdr_ratio = "";
* max_hdr_ratio = "";
* HDR Ratio limits for mode
* min_framerate = "";
* max_framerate = "";
* Framerate limits for mode (fps)
* embedded_metadata_height = "";
* Sensor embedded metadata height in units of rows.
* If sensor does not support embedded metadata value should be 0.
mode0 { // IMX274_MODE_3840X2160
mclk_khz = "24000";
num_lanes = "4";
discontinuous_clk = "yes";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "3840";
active_h = "2160";
pixel_t = "bayer_rggb";
readout_orientation = "90";
line_length = "4208";
inherent_gain = "1";
mclk_multiplier = "24";
pix_clk_hz = "576000000";
min_gain_val = "1.0";
max_gain_val = "22.2";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
min_framerate = "1.5";
max_framerate = "30";
min_exp_time = "44";
max_exp_time = "666637";
mode1 { // IMX274_MODE_1920X1080
mclk_khz = "24000";
num_lanes = "4";
active_w = "1920";
active_h = "1080";
line_length = "4160";
max_framerate = "60";
min_exp_time = "58";
max_exp_time = "184611";
embedded_metadata_height = "1";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
liimx274_imx274_out0: endpoint {
status = "okay";
csi-port = <0>;
bus-width = <4>;
remote-endpoint = <&liimx274_csi_in0>;
lens_imx274@A6V26 {
min_focus_distance = "0.0";
hyper_focal = "0.0";
focal_length = "5.00";
f_number = "2.0";
aperture = "2.2";
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <4>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <750000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. "rear" or "front".
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vender.
modules {
module0 {
badge = "imx274_bottom_A6V26";
position = "bottom";
orientation = "1";
drivernode0 {
/* Declare PCL support driver (classically known as guid) */
pcl_id = "v4l2_sensor";
/* Driver v4l2 device name */
devname = "imx274 30-001a";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/host1x/i2c@546c0000/tca9546@70/i2c@0/imx274_a@1a";
drivernode1 {
pcl_id = "v4l2_lens";
proc-device-tree = "/proc/device-tree/lens_imx274@A6V26/";
tegra210-jetson-cv-camera-modules.dtsi:
* the Free Software Foundation; version 2 of the License.
* more details.
#include "tegra210-jetson-cv-camera-imx274-a00.dtsi"
#include "tegra210-jetson-cv-camera-imx185-a00.dtsi"
#include "tegra210-jetson-cv-camera-e3333-a00.dtsi"
#include "tegra210-jetson-cv-camera-e3326-a00.dtsi"
#include "tegra210-jetson-cv-camera-e3323-a00.dtsi"
#define CAM0_RST_L TEGRA_GPIO(S, 4)
#define CAM0_PWDN TEGRA_GPIO(S, 7)
#define CAM1_RST_L TEGRA_GPIO(S, 5)
#define CAM1_PWDN TEGRA_GPIO(T, 0)
/* set camera gpio direction to output */
gpio: gpio@6000d000 {
camera-control-output-low {
gpio-hog;
output-low;
gpios = <CAM0_RST_L 0 CAM0_PWDN 0
CAM1_RST_L 0 CAM1_PWDN 0>;
label = "cam0-rst", "cam0-pwdn",
"cam1-rst", "cam1-pwdn";
/* all cameras are disabled by default */
host1x {
vi_base: vi {
ports {
vi_port0: port@0 {
status = "okay";
vi_in0: endpoint {
status = "okay";
vi_port1: port@1 {
status = "disabled";
vi_in1: endpoint {
vi_port2: port@2 {
vi_in2: endpoint {
vi_port3: port@3 {
vi_in3: endpoint {
vi_port4: port@4 {
vi_in4: endpoint {
vi_port5: port@5 {
vi_in5: endpoint {
csi_base: nvcsi {
csi_chan0: channel@0 {
status = "okay";
ports {
csi_chan0_port0: port@0 {
status = "okay";
status = "okay";
csi_chan0_port1: port@1 {
status = "okay";
status = "okay";
csi_chan1: channel@1 {
ports {
csi_chan1_port0: port@0 {
csi_in1: endpoint@2 {
csi_chan1_port1: port@1 {
csi_out1: endpoint@3 {
csi_chan2: channel@2 {
ports {
csi_chan2_port0: port@0 {
csi_in2: endpoint@4 {
csi_chan2_port1: port@1 {
csi_out2: endpoint@5 {
csi_chan3: channel@3 {
ports {
csi_chan3_port0: port@0 {
csi_in3: endpoint@6 {
csi_chan3_port1: port@1 {
csi_out3: endpoint@7 {
csi_chan4: channel@4 {
ports {
csi_chan4_port0: port@0 {
csi_in4: endpoint@8 {
csi_chan4_port1: port@1 {
csi_out4: endpoint@9 {
csi_chan5: channel@5 {
ports {
csi_chan5_port0: port@0 {
csi_in5: endpoint@10 {
csi_chan5_port1: port@1 {
csi_out5: endpoint@11 {
i2c@546c0000 {
e3326_cam0: ov5693_c@36 {
e3323_cam0: ov23850_a@10 {
e3323_vcm0: lc898212@72 {
cam_tca6408_21: tca6408@21 {
cam_tca9548_77: tca9548@77 {
i2c@0 {
e3333_cam0: ov5693_a@36 {
i2c@1 {
e3333_cam1: ov5693_b@36 {
i2c@2 {
e3333_cam2: ov5693_c@36 {
i2c@3 {
e3333_cam3: ov5693_d@36 {
i2c@4 {
e3333_cam4: ov5693_e@36 {
i2c@5 {
e3333_cam5: ov5693_f@36 {
default {
gpio-output-low = <0 1 2 3 4 5 6 7>;
tca9546_70: tca9546@70 {
status = "okay";
i2c@0 {
imx185_cam0: imx185_a@1a {
imx274_cam0: imx274_a@1a {
status = "okay";
i2c@7000c000 {
e3323_cam1: ov23850_c@36 {
e3323_vcm1: lc898212@72 {
tcp: tegra-camera-platform {
num_csi_lanes = <2>;
max_pixel_rate = <408000>;
isp_peak_byte_per_pixel = <2>;
modules {
cam_module0: module0 {
cam_module0_drivernode0: drivernode0 {
cam_module0_drivernode1: drivernode1 {
cam_module1: module1 {
cam_module1_drivernode0: drivernode0 {
cam_module1_drivernode1: drivernode1 {
cam_module2: module2 {
cam_module2_drivernode0: drivernode0 {
cam_module2_drivernode1: drivernode1 {
cam_module3: module3 {
cam_module3_drivernode0: drivernode0 {
cam_module3_drivernode1: drivernode1 {
cam_module4: module4 {
cam_module4_drivernode0: drivernode0 {
cam_module4_drivernode1: drivernode1 {
cam_module5: module5 {
cam_module5_drivernode0: drivernode0 {
cam_module5_drivernode1: drivernode1 {
So, I can’t find the problem with device tree, Could you help me about this issue ?
